Old 06-01-2007, 07:28 AM   #1 (permalink)
TeCh Blogger : Gtechinfo
gau_pppu's Avatar
Default Minimum requirement for vista
I want to know that what is the minimum hardware requirement requirement foer windows Vista, to run in a computer.................
gau_pppu is offline
Old 06-01-2007, 10:36 AM   #2 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Default Re: Minimum requirement for vista
Check this link:
http://www.microsoft.com/windowsvist...r/default.mspx
u will find an option to download an application called windows vista upgrade advisor, u can download it n install it on your pc. It will give you detailed info of which components are vista ready and which are not on your pc
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 06-01-2007, 10:59 AM   #3 (permalink)
assasin's Avatar
It depends on wat version of Vista ur planning to run.Dont fall for the minimum requirements posted by Microsoft,its crap.U'll need a more powerfull pc dan that to run Vista.
assasin is offline
Old 06-01-2007, 11:06 AM   #4 (permalink)
GaurishSharma.com
gary4gar's Avatar
they say 256 mb is enough to run vista without AERO
now who is leaving XP & going to 2000??
gary4gar is offline
Old 06-01-2007, 11:10 AM   #5 (permalink)
soham's Avatar
Who says 256 MB is enough to run Vista without AERO. Microsoft a made it clear that 512 MB of RAM is the bare minimum for running Vista without AERO branded as Vista capable and 1024 MB for running Vista with all the frills branded as Vista Premium.
"Imagination is more important than knowledge. For knowledge is limited, whereas imagination embraces the entire world, stimulating progress, giving birth to evolution." ~ Albert Einstein
soham is offline
Old 06-01-2007, 01:38 PM   #6 (permalink)
1 gb is needed for smooth operation of vista with aero.......more ram the better
Sony Vaio CW26FG
Old 06-01-2007, 01:49 PM   #7 (permalink)
Texan
anniyan's Avatar
1 GB ram!!!!!!!!!! Mic#@# S#@$#
anniyan is offline
Old 06-01-2007, 02:10 PM   #8 (permalink)
kirtan's Avatar
yes man 1GB is the minimum requirement for the smooth operation of the vista.Even my 512MB RAM could not operate smoothly with the beta version of vista
Water can flow or it can crash.Be Water my friend.
kirtan is offline
Old 06-01-2007, 02:18 PM   #9 (permalink)
Super Hero - Super Powers
n2casey's Avatar
I don't know how but Vista is running without Aero on my PC with config.
P - 4 (1.7 GHz)
256 MB RAM
40 GB HDD (7200 rpm)
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 07-01-2007, 09:45 AM   #10 (permalink)
assasin's Avatar
Den ur a 1 in a million n2casey,cuz Vista doesnt even start to install in PCs having 256MB of Ram.
assasin is offline
Old 07-01-2007, 09:56 AM   #11 (permalink)
morpheusv6's Avatar
Isn't there a sticky in the software troubleshooting section(now closed)?
http://www.thinkdigit.com/forum/showthread.php?t=38900
Deven
morpheusv6 is offline
Old 07-01-2007, 09:58 PM   #12 (permalink)
No, friend 1Gb ram is not enough for running Vista if you don't have a somewhat better graphic card. I have D101GGC which have ATi X200 onboard graphic card. But when i run any movie in VLC player vista will automatically apply basic Aero theme from the AERO and when VLC closed, back to AERO.
abhipal is offline
