Old 05-01-2007, 12:28 PM   #1 (permalink)
Default i forgot my ipod code to open menu. . . help
i forgot the security code to unlock my menu options to use my ipod . please help me to enter the code and to reset it . . . . . . . thank you
www.mechroyals.host.sk
web site for all mechanical engineer's.. come in share us
steelwin is offline
Old 05-01-2007, 02:19 PM   #2 (permalink)
The Devil's Advocate
iMav's Avatar
Default Re: i forgot my ipod code to open menu. . . help
use itunes to restore ur ipod
http://beingmanan.com
iMav is offline
Old 05-01-2007, 03:53 PM   #3 (permalink)
The High 5 Flyer
sam9s's Avatar
google it and you will get loads of options and opinions to reset ipod.
sam9s is offline
Old 05-01-2007, 05:56 PM   #4 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
press the reset button ........ or read the manual .........
ax3 is offline
