Hi
i have a strange problem.when i play dvd/cd sound is not ok.some kind of disturbing noise (like crackling sound) and some time video is also not smooth. but when i play song or videos from hard disk sound is perfectly fine.
i have LG combo drive.
what are the various settings for drive like dma and how to change them.i think data is not getting transfered properly.
please help
pal this crackling sound is common in LG combos..no need to worry abt...although u can go 4 a lens cleaner cd to clean up the dust on the lens of ur drive...this will rduce that sound a bit...try it..
I have cleaned the drive but sound is still there.
and one thing sound is not coming from drive but it is in movie and i hear it in speakers.
which mode is better for data transfer DMA or PIO. and how to change the mode.
drive is one and half yr old.
drive is LG HL-DT-ST RW/DVDGCC-4521B
where i can find drivers for it?
help
thanx
__________
Problem is solved.
i opened th drive then applied vaseline(very small amount) to the sliding assembly of drive and it worked fine after that.
is there any specific lubricating creme is outthere to be applied.?
and what is the best thermal paste?
it is summer here and my system is little slow and i think it is due to cpu heating because i once opened the assembly and little paste got removed.
please help
thanx
Reason: Automerged Doublepost
hi
Problem surfaced again.
is there any software to test cd/dvd performance(seek time etc.).please let me know. i would run test and post the log file or compare with standards.
hi
i am posting the results fromthe nero cd speed.
please have look at them point out what is the problem.
theoratical speed is 52x but test speds are very low. i think thats why dvd movies are not playing properly. audio and mp3 are working fine.is there any software or setting which might have limited the speed or my drive is near its death.
please help.
thanx
below are the results from nero cd speed.
General Information
Operating System Windows XP
Drive HL-DT-STRW/DVD GCC-4521B
Firmware Version 1.06
Serial Number
Disc Data CD
Capacity 70:04.04
Transfer Rate
Start 16.14x
End 4.41x
Average 14.87x
Type CLV
Seek Times
Random 201 ms
1/3 271 ms
Full 303 ms
CPU Usage
1X 8 %
2X 100 %
4X 100 %
8X 100 %
Interface
Burst Rate 353 KB/sec
Spin Up/Down Times
Spin Up Time 2.16 sec
Spin Down Time 0.99 sec
Load/Eject Times
Load Time 1.06 sec
Eject Time 1.36 sec
Recognition Time 8.28 sec
Log
Time Elapsed Action
[16:20:46] Starting Transfer Rate Test
[16:27:48] 7:02 Speed:16 X CLV (14.87 X average)
[16:27:48] Starting Seek Times Test
[16:28:09] Random seek: 201 ms
[16:28:36] 1/3 seek: 271 ms
[16:29:06] 1:18 Full seek: 303 ms
[16:29:06] Starting CPU Usage Test
[16:29:21] CPU usage at 1X: 8 %
[16:29:37] CPU usage at 2X: 100 %
[16:30:08] CPU usage at 4X: 100 %
[16:30:55] 1:49 CPU usage at 8X: 100 %
[16:30:55] Starting Burst Rate Test
[16:31:38] 0:43 Interface burst rate: 0 MB/sec (353 KB/sec)
[16:31:38] Starting Spin-Up/Down Test
[16:31:41] Spin-up time: 2.16 seconds
[16:31:52] 0:14 Spin-down time: 0.99 seconds
[16:31:52] Starting Load/Eject Test
[16:31:54] Eject time: 1.36 seconds
[16:31:55] Load time: 1.06 seconds
[16:32:03] 0:11 Recognition time: 8.28 seconds
