Old 05-01-2007, 07:33 AM   #1 (permalink)
shyamno's Avatar
Question Suggest Me a Motherboard supporting DDR and DDR2
Guys Please suggest be a good motherboard supporting both DDR and DDR2 type of memory..(both found in India and abroad)..
If it supports D or C2D it will be an added advantage..
shyamno is offline
Old 06-01-2007, 04:27 PM   #2 (permalink)
ECE0105's Avatar
Default Re: Suggest Me a Motherboard supporting DDR and DDR2
DDR and DDR2 have different types of slots. So, I am not sure whether any Mobo Supports both these.
ECE0105 is offline
Old 10-01-2007, 05:06 AM   #3 (permalink)
Fast 'N' Furious
topgear's Avatar
Mercury PI915GVM
Specs: Socket LGA775, PCI-Express architecture, Onboard Intel graphics,
10/100 LAN, Four USB 2.0 Ports.
Supports up to 2 GB DDR as well as DDR2 memory at 400 MHz and 533 MHz respectively. Six channel onboard audio
Not Sure if the mobo has Sata ports so check it out at
http://www.mercury-pc.com
Also I don't know the current price. Probably it don't supports Dual core or core 2 duo processors.
topgear is offline
Old 10-01-2007, 10:45 AM   #4 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
check out this mobo
Asus P5GDC-V....
wizrulz is offline
