Old 04-01-2007, 04:00 PM   #1 (permalink)
anarchy0x's Avatar
Exclamation RAM backward compatiability
What will happen if i try to use my 256 DDR RAM of speed 266 with a DDR RAM of different RAM different speed ..say 256/512 MB DDR speed=677 or 256/512 MB DDR speed=533 or any other speed. I have head about RAM's backward compatiability , does it mean that if i try to run my RAM of speed 266 with any RAM of greater speed both will run at the lowest speed i.e 266 ??
Also if i want to use the 256 MB speed 266 with a RAM of greater speed,is there any limit the higher RAM should have, say it should not be above 677 or something like that?
anarchy0x is offline
Old 04-01-2007, 04:34 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: RAM backward compatiability
Yeah both will run at the least level of speed. Most of the times problems occur while doing so. But I don't know of a limit other than the one set by your motherboard.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 04-01-2007, 04:41 PM   #3 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
=>>> YES
I do not thing that will matter
wizrulz is offline
Old 04-01-2007, 05:33 PM   #4 (permalink)
anarchy0x's Avatar
My MOBO is intel 865 GBF
thanks both of u 4 replying
Old 04-01-2007, 09:05 PM   #5 (permalink)
anarchy0x's Avatar
ty ..best of luck lol
i think it' ll run fine & if u do encounrter problems that ll b very occassionally but i dont think u ll get any problems
