Old 03-01-2007, 07:34 PM   #1 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
Unhappy Pc Restarts While Working! .....plz Help
while i work the pc restarts automatically in between.........
i have turned off the automatically restart option too.. but still the prb. persists.
specs are :-
P IV 3.0 GHz
Intel 915G Chipset
1GB DDR RAM
Any help would be appreciated
Blackberry7100g
BBThumbHealer is offline
Old 03-01-2007, 07:54 PM   #2 (permalink)
Kiran.dks's Avatar
Default Re: Pc Restarts While Working! .....plz Help
It seems RAM problem. Check the RAM connection. Remove it, clean the slot and insert it. If not resolving, try another RAM.
Kiran Kumar R
Kiran.dks is offline
Old 03-01-2007, 09:02 PM   #3 (permalink)
thanx! i'll try
but ......
do u have any other option also(except changing the RAM)
Old 03-01-2007, 09:11 PM   #4 (permalink)
The problem could also be in PSU, overall config drawing more power than what PSU can handle or even faulty mobo / reset switch!
What's the Wattage of your power supply (PSU)
My office PC behaved the same way and we found the motherboard to have gone faulty.
patkim is offline
Old 04-01-2007, 01:16 PM   #5 (permalink)
Cool G5's Avatar
Post Re: Pc Restarts While Working! .....plz Help
First try the kiran method.Otherwise it can be due to overheating cpu.Remove the cpu,clean it & then install it.Also If u have two ram modules try interchaning their slots.(It had happened with me).
Cool G5 is offline
Old 23-01-2007, 06:47 PM   #6 (permalink)
changed the RAM ......cleaned the CPU...interchanged the slots ...but prb still persists !!
can the HDD also cause prbs ?
BlackBerry7100g.
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
Old 23-01-2007, 07:03 PM   #7 (permalink)
Security Exp
47shailesh's Avatar
Do you get any error message before ur system restarts.. or it just goes down without any message.. if is it so than overheating may be an area of concern... ensure adequte cooling in the cabinate..
Use thermal paste to keep ur CPU cool....
We Love Once, And When We do We do it Well
47shailesh is offline
Old 23-01-2007, 07:11 PM   #8 (permalink)
it goes down without any message... n overheating is not the issue !!
ne other option or is nething wrong with the HDD ?
Old 23-01-2007, 07:17 PM   #9 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
keep side panel of ur CPU open....also if possible install SPEEDfan to know temp of ur system....also if possible run MEMTEST on ur RAMS
wizrulz is offline
Old 23-01-2007, 07:28 PM   #10 (permalink)
Security Exp
47shailesh's Avatar
Can you please some details of your PSU... How r u so sure that overheating isn't an issue ???
Old 23-01-2007, 07:47 PM   #11 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Smile Re: Pc Restarts While Working! .....plz Help
this problem is not related HW section there is problem with OS i also face this problem when i re-install the xp into my system its solve i think VISHAL can slove this problem very easily.(REG GURU MVP)
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Old 23-01-2007, 08:04 PM   #12 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Can u access your folder options n registry? Try accessing them , if u cant then u are infected with BRONTOK virus.........use kaspersky to get rid of it or else format.........
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 23-01-2007, 09:47 PM   #13 (permalink)
Security Exp
47shailesh's Avatar
do you use prirated XP.. and any anti virus..
I too have faced this prob... with XP(pirated) when i installed XP and NAV2006 an year ago ..when i updated NAV exactly prob like ur started to occur then i tried another XP (again pirated) and that worked frm then till now i have no probs...
Old 25-01-2007, 11:57 AM   #14 (permalink)
well i totally agree with blackberry,
i m facing this damn problem for the last 2 months but one thing i want to tell u all that i hear a creaking sound before the comp. restarts nd it can restart basically at any time,when its working,idle or downloading,i m fed up...
i took my cpu to my vendor but the sound that i hear didn,t come at their place so i m stuck so please can anybody in this world help me....
thanx
rjasthebest is offline
Old 25-01-2007, 01:12 PM   #15 (permalink)
Security Exp
47shailesh's Avatar
thanx
change the BUS that connect ur HDD to Mobo.. or try repalcing the same..
also ensure that pins to which u insert ur buses are OK on both the end (i.e. mobo and HDD ends)....
Old 25-01-2007, 09:38 PM   #16 (permalink)
I think it PSU - Voltage Related Problem.
Stick is offline
Old 25-01-2007, 09:57 PM   #17 (permalink)
 Macboy
goobimama's Avatar
@wizrulz: Keeping the side panel open doesn't mean better cooling. In fact, the airflow in the cabinet is totally messed up.
Doesn't seem like he's got a hardware problem though...
To check whether its Windows or not, just don't let it boot into the OS. Press DEL or F8 to stop the loading of windows. If it still shuts down then its definitely a Hardware issue...
I'm like a bird... :)
goobimama is offline
Old 25-01-2007, 11:22 PM   #18 (permalink)
shantanu's Avatar
It can be a problem of PSU or any WRONG BIOS SETTING SO FIRST RESTORE DEFAULTS IN YOUR BIOS.
shantanu is offline
Old 26-01-2007, 12:16 AM   #19 (permalink)
The Transcendental
Guys Guys !! You should start from the grassroots level.
First, the software part.
No diff b/w genuine/nongenuine OS but I do not recommend installing WGA and antWGA patches which can mess things up.
Now, how long have you been having this problem?
Check if System Restore to a previous date (before the problem occurred is possible and try it.
If not try to remember if you installed some new drivers or software.
For instance, I can reproduce this problem on my system using old creative drivers or the Logitech Mouseware (always causes my system to reboot at awkward times).
Pesky malware or even an ovezealous firewall (like the norton, mcafee bloatware) can cause driver conflicts.
Are you having the problem on another OS.
Try installing Win98 or Linux.
If the problem persists on other operating systems then certainly, the fault is in hardware.
The PSU may be sending variable power or even the UPS.
If you are not using a UPS, then perhaps you may be having voltage fluctuations or maybe the socket may be shorting.
Now after these go on check your RAM or even your hard disk( may be developing bad sectors). Run checkdisk for the latter.
Then come see us again.
:::::::::: When freedom is outlawed, only outlaws will have freedom ::::::::::
..:: Free Radical ::.. is offline
Old 26-01-2007, 12:51 AM   #20 (permalink)
 Macboy
goobimama's Avatar
Software runs atop the hardware. So grassroots here would be hardware...wouldn't it?
Old 26-01-2007, 12:54 AM   #21 (permalink)
shantanu's Avatar
^^^ yeah i agree with you .. grass roots are hardware only
shantanu is offline
Old 26-01-2007, 03:23 PM   #22 (permalink)
hey ppl.....thank u for ur efforts to solve my prbs...
i wud like to tell u ppl that i m having genuine windows xp sp2 ... voltage isn't a prb coz i got my SMPS replaced...formatted my XP and reloaded but prb still persists....and for u codename_romeo, i m able to access my registry and folder options....my PC is virus-free....
Thanking u all again...but plz keep on tryin for a soln...
BLACKBERRY7100g
Old 26-01-2007, 05:22 PM   #23 (permalink)
well free radical,i have installed win 98 nd still the problem exists..
my hard disk is ok as i did chkdisk nd no errors came,also checked my ram by memtest no problems there either......
BUT ONE THINK IS HARD TO UNDERSTAND THAT WHY DID THE COMPUTER DID NOT RESTART WHEN I TOOK MY CPU TO MY VENDOR'S PLACE<<
WHAT THE HELL MAN,i m confused lots
Old 26-01-2007, 05:49 PM   #24 (permalink)
The Transcendental
Did you also perform a surface scan?
try using your hard disk and/or ram on another system.
can you reproduce the problem then?
Old 26-01-2007, 06:42 PM   #25 (permalink)
 Macboy
goobimama's Avatar
If it didn't restart at the vendors place, then something may be wrong with your home wiring. Get plug checked for leakages and such eh?
Old 26-01-2007, 08:09 PM   #26 (permalink)
shantanu's Avatar
This Is Surely Problem With Ups... I Got Same Problem Yesterday And The System Restarted Withour Any Notice Any Time !!!!!
Damn Sure Your Ups Is Having Problem Or Your Voltage Is Bad... Check Your Power
shantanu is offline
Old 13-08-2007, 11:35 AM   #27 (permalink)
hellloooo,,,,,
m back with this thread............well i want u to tell u all is that............i couldn't find a soln to this problem last year in winters...........but I wanna tell u that this restarting problem vanished in summers here in chandigarh..........but poor me coz of the rain its somewhat cooler here nd this damn problem has arrived again.......i hear the same creaking sound nd my pc restarts without any prior notice.........
PLS HELP ME........
HOPE TO FIND A SOLN THIS TIME AROUND...............
