View Poll Results: last month's digit dvd didnt work on my pc.rom doesnt read the devd even.thereis no
sometimes may happen 0 0%
dvd is corrupt 0 0%
dvd rw is nt working 0 0%
cant say anything 1 100.00%
Voters: 1. You may not vote on this poll
Old 03-01-2007, 11:57 AM   #1 (permalink)
I'll xploit ur Territory
niraj trehan's Avatar
Default bad dvd format or bad dvd rom
last month's digit dvd didnt work on my pc.rom doesnt read the devd even.thereis no crack or scratch on dvd evn.all other dvd's work fine.evn previous versions go pretty gud.
i have dual core 2.8
1gig ram
dvd rw sony
this dvd works perfect on my friend's pc.what can b problm?
<<XFX 680i TLi chipset>>Dual core 2.8Ghz>>2*1GbTranscend 800 hz>>8800 GTX XXX 768 Mb..GTX 260 862 Mb now GTX 280 1 Gb>>Cabbi CM 690 Nvidia SLI>>CM OEM 600w>>APC 1Kva UPS>>
niraj trehan is offline
Old 03-01-2007, 12:43 PM   #2 (permalink)
Kiran.dks's Avatar
Default Re: bad dvd format or bad dvd rom
You should have the following requirements:
16-bit hi-colour
Display set to atleast 800x600 resolution
IE6 or above
Flash Player 8
Kiran Kumar R
Kiran.dks is offline
