Old 03-01-2007, 10:30 AM   #1 (permalink)
Unhappy Wats Wrong With My DVD Writer??? Help Me Plz....
Hi friends i have bought Sony DVD writer about a year back and it worked fine for about 7 months and from then it started giving errors while burning DVD's. Slowly after some days DVD's which are burned in my Drive only are started detecting and none other. And nw recently it stopped burning CD's also.... wats the problem with this??? Is there any solution for this??? Please help me friends.....
RoughGuy is offline
Old 03-01-2007, 11:14 AM   #2 (permalink)
Kiran.dks's Avatar
Default Re: Wats Wrong With My DVD Writer??? Help Me Plz....
What about reading CD's and DVD's ? Is it working perfectly?
Kiran Kumar R
Kiran.dks is offline
Old 03-01-2007, 11:22 AM   #3 (permalink)
Google Bot
Pathik's Avatar
wat error do u get wen u try to burn dvds/cds
Pathik is offline
Old 03-01-2007, 09:48 PM   #4 (permalink)
anbuthane's Avatar
This might be due to th DMA .
check if
>Ur drive is on the DMA mode it supports
>Do a Nero CD-DVD speed test to see the performance of ur cd drive
>the drive will show poor performance if the lens is clogged with dust particles try a cd lens cleaner solution (this is also experienced if the drive works on PIO mode
anbuthane is offline
Old 04-01-2007, 10:19 AM   #5 (permalink)
Thanks a lot for ur solutions friends... but i dint get wats DMA mode??? and hw 2 test the CD_DVD speed test???? plz help me friends.....
RoughGuy is offline
Old 05-01-2007, 10:43 AM   #6 (permalink)
This is the error report im getting....
Windows 2000 5.0
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/17/2002 9:20:56 AM
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 6:35:34 PM
Nero Version: 6.6.0.15
Internal Version: 6, 6, 0, 15h
 (Nero Express)
Recorder:             <SONY DVD RW DW-Q28A>     Version: KYS3 - HA 0 TA 1 - 6.6.0.15
 Adapter driver:      <atapi>                   HA 0
 Drive buffer  :      2048kB
 Bus Type      :      default (0) -> ATAPI, detected: ATAPI
CD-ROM:               <SONY     DVD RW DW-Q28A  >Version: KYS3 - HA 0 TA 1 - 6.6.0.15
=== Scsi-Device-Map ===
DiskPeripheral       : SAMSUNG SV2044D                  atapi Port 0 ID 0  DMA: On
CdRomPeripheral      : SONY DVD RW DW-Q28A              atapi Port 0 ID 1  DMA: Off
CdRomPeripheral      : NERO    IMAGEDRIVE2     2.26  imagedrv Port 2 ID 0  DMA: Off
=== CDRom-Device-Map ===
SONY DVD RW DW-Q28A        E:   CDRom0
NERO IMAGEDRIVE2           F:   CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 73400320 (0) Byte
ShowDrvBufStat : 0
BUFE           : 0
Physical memory     : 503MB (515572kB)
Free physical memory: 163MB (167136kB)
Memory in use       : 67 %
Uncached PFiles: 0x0
Use Inquiry    : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
14.9.2006
ISO compilation
9:17:14 AM	#1 Text 0 File Isodoc.cpp, Line 6314
	Iso document burn settings
	Determine maximum speed : FALSE
	Simulate                : FALSE
	Write                   : TRUE
	Finalize CD             : FALSE
	Multisession            : TRUE
	Multisession type:      : Start multisession
	Burning mode            : DAO
	Mode                    : 1
	ISO Level               : 1 (Max. of 11 = 8 + 3 char)
	Character set           : ISO 9660
	Joliet                  : TRUE
	Allow pathdepth more than 8 directories : TRUE
	Allow more than 255 characters in path  : TRUE
	Write ISO9660 ;1 file extensions        : TRUE
9:17:14 AM	#2 Text 0 File Reader.cpp, Line 127
	Reader running
9:17:14 AM	#3 Text 0 File Writer.cpp, Line 122
	Writer SONY     DVD RW DW-Q28A   running
9:17:14 AM	#4 ISO9660GEN -11 File geniso.cpp, Line 3309
	First writeable address = 0 (0x00000000)
9:17:15 AM	#5 Text 0 File Burncd.cpp, Line 3231
	Turn on Disc-At-Once, using DVD media
9:17:15 AM	#6 Text 0 File DlgWaitCD.cpp, Line 269
	Last possible write address on media:  2298495 (510:46.45, 4489MB)
	Last address to be written:             579199 (128:42.49, 1131MB)
9:17:15 AM	#7 Text 0 File DlgWaitCD.cpp, Line 281
	Write in overburning mode: NO (enabled: CD)
9:17:15 AM	#8 Text 0 File DlgWaitCD.cpp, Line 2477
	Recorder: SONY DVD RW DW-Q28A, Media type: DVD-R
	 Disc Manufacturer: TYG02 -
	 Disc Application Code: 64, Disc Physical Code: 193
9:17:15 AM	#9 Text 0 File DlgWaitCD.cpp, Line 447
	>>> Protocol of DlgWaitCD activities: <<<
9:17:15 AM	#10 Text 0 File ThreadedTransferInterface.cpp, Line 830
	Setup items (after recorder preparation)
	 0: TRM_DATA_MODE1 ()
	    2 indices, index0 (150) not provided
	    original disc pos #0 + 579200 (579200) = #579200/128:42.50
	    relocatable, disc pos for caching/writing not required/ required, no patch infos
	    -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 579200 blocks [SONY     DVD RW DW-Q28A]
9:17:15 AM	#11 Text 0 File ThreadedTransferInterface.cpp, Line 1043
	Prepare recorder [SONY     DVD RW DW-Q28A] for write in CUE-sheet-DAO
	DAO infos:
	 MCN: ""
	 TOCType: 0x00; Session Closed, disc not fixated
	 Tracks 1 to 1:
	   1: TRM_DATA_MODE1, 2048/0x00, FilePos             0             0    1186201600, ISRC ""
	DAO layout:
	 __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
	       0 |  lead-in |   0 |    0x41 | 0x00
	       0 |        1 |   0 |    0x41 | 0x00
	       0 |        1 |   1 |    0x41 | 0x00
	  579200 | lead-out |   1 |    0x41 | 0x00
9:17:15 AM	#12 Phase 24 File dlgbrnst.cpp, Line 1832
	Caching of files started
9:17:28 AM	#13 Text 0 File Burncd.cpp, Line 4116
	Cache writing successful.
9:17:28 AM	#14 Phase 25 File dlgbrnst.cpp, Line 1832
	Caching of files completed
9:17:28 AM	#15 Phase 36 File dlgbrnst.cpp, Line 1832
	Burn process started at 6x (8,310 KB/s)
9:17:29 AM	#16 Text 0 File ThreadedTransferInterface.cpp, Line 2643
	Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
9:17:29 AM	#17 Text 0 File DVDR.cpp, Line 2357
	Recording mode: Sequential Recording Mode for Multisession
9:17:29 AM	#18 Text 0 File Mmc.cpp, Line 21663
	Set BUFE: Power-Burn -> ON , Adapt writespeed to disc : ON
9:17:29 AM	#19 Text 0 File DVDR.cpp, Line 2511
	Start write address at LBA 0
	DVD high compatibility mode: Yes
9:17:29 AM	#20 Text 0 File Cdrdrv.cpp, Line 8821
	---- DVD Structure: Physical Format Information (00h) ----
	Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
	 Book Type: DVD-R   (2), Part Version: 5
	 Disc Size: 120 mm,      Maximum Rate: 10.08 Mbps (2 h)
	 Number of Layers: 1,    Track Path: Parallel Track Path (PTP),  Layer Type: recordable
	 Linear Density:         0,267 um/bit,  Track Density:  0,74 um/track
	 Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
	 End Physical Sector Number of Data Area:      0 h
	 End Sector Number in Layer 0:                 0 h (LBN: FFFD0000 h, 4193920 MB)
	 Data in Burst Cutting Area (BCA) does not exist
	  Start sector number of the current Border-Out: 0 h
	  Start sector number of the next Border-In:     0 h
	 Media Specific [16..63]:
	      00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00    ................
9:18:41 AM	#21 SCSI -1106 File Cdrdrv.cpp, Line 1436
	SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x0B540000
	Status:     0x04 (0x01, SCSI_ERR)
	HA-Status   0x00 (0x00, OK)
	TA-Status   0x02 (0x01, SCSI_TASTATUS_CHKCOND)
	Sense Key:  0x03 (KEY_MEDIUM_ERROR)
	Sense Code: 0x73
	Sense Qual: 0x03
	CDB Data:   0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
	Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
	            0x00 0x00 0x00 0x00 0x73 0x03
9:18:41 AM	#22 CDR -1106 File Writer.cpp, Line 311
	Power calibration error
9:18:41 AM	#23 Text 0 File ThreadedTransfer.cpp, Line 228
	all writers idle, stopping conversion
9:18:41 AM	#24 Text 0 File ThreadedTransfer.cpp, Line 222
	conversion idle, stopping reader
9:18:41 AM	#25 Text 0 File DVDR.cpp, Line 2749
	EndDAO: Last written address was -1
9:18:41 AM	#26 Phase 133 File dlgbrnst.cpp, Line 1832
	Writing short lead-out
9:18:41 AM	#27 SCSI -1176 File Cdrdrv.cpp, Line 1182
	Sense Key:  0x05 (KEY_ILLEGAL_REQUEST)
	Sense Code: 0x72
	Sense Qual: 0x04
	CDB Data:   0x5B 0x01 0x02 0x00 0x00 0x03 0x00 0x00 0x00 0x00 0x00 0x00
	Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
	            0x00 0x00 0x00 0x00 0x72 0x04
9:18:41 AM	#28 CDR -1176 File WriterStatus.cpp, Line 167
	Session fixation error
9:18:41 AM	#29 TRANSFER -24 File WriterStatus.cpp, Line 167
	Could not perform end of Disc-at-once
9:18:41 AM	#30 Phase 38 File dlgbrnst.cpp, Line 1832
	Burn process failed at 6x (8,310 KB/s)
Existing drivers:
File 'Drivers\CDR4_2K.SYS': Ver=8.0.0.212 , size=2432 bytes, created 5/20/2006 2:46:24 AM
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 5/20/2006 2:46:24 AM
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 7/17/2002 8:53:02 AM
File 'Drivers\PXHELP20.SYS': Ver=3.00.11B, size=46080 bytes, created 5/17/2006 1:53:54 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.00.2195.6699, size=86672 bytes, created 6/18/2003 12:00:00 PM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
RoughGuy is offline
