01-01-2007, 08:10 PM
blue ray drive
i am looking for a good dvd read write drive.can u guys suggest me any?
is blue ray compatible dvd drive available in india.if yes how much does it cost.
01-01-2007, 08:17 PM
Re: blue ray drive
Everyone does not hve a blu ray drive. so it is some what useless.
Go for a sony or a Lite on drive
01-01-2007, 09:15 PM
Re: blue ray drive
There arent any blue ray compatible dvd drives. either blue ray drives which read dvds as well or simply dvd drives. You may get some through the grey market at around 50k. Better get a PS3 even if it costs you 50k. You get a lot more than a blue ray drive.
"Imagination is more important than knowledge. For knowledge is limited, whereas imagination embraces the entire world, stimulating progress, giving birth to evolution." ~ Albert Einstein
01-01-2007, 09:28 PM
Commander in Chief
Re: blue ray drive
soham - Buying a PS3 is hell lot different than buying a Blu-Ray disc drive! Think of data discs here ... :/
@OP - Blu-Ray is still not really cheap to afford or easily available to go mainstream in India. Its better you get a 16x normal burner or look for slightly higher speeds such as 18x and 20x which have entered the market quite recently.
Harsh J
www.harshj.com
01-01-2007, 10:25 PM
ANGEL OF DEATH
Re: blue ray drive
 If you really want a good drive then check cdrlabs or cdfreaks or cdrinfo. Majority opinion deciding your purchase is real lame
the new Sony DRU830A is *MADE BY SAMSUNG*. Wake up!
| Dell 15z + WD 2TB | | Dell Studio 1555 + WD 1TB | | iPhone 4 32 GB | | Samsung Galaxy S2 White | | Good Desktop Power Of C2D + 4850 |
02-01-2007, 05:48 AM
Re: blue ray drive
Qwerty - i only meant a Blue Ray reader here. Even the readers cost no less than 800$. So if you are interested in only playing Blue ray disks, PS3 is tat bad a deal.
05-01-2007, 07:24 PM
Re: blue ray drive
thanks guys.i am thinking of buying the one suggested by digit in december issue.what du people say?
06-01-2007, 12:37 AM
Re: blue ray drive
go for it
06-01-2007, 01:43 AM
Macboy
Re: blue ray drive
Pointless buying either of the drives (blu ray or HD DVD). Dual format readers/writers are just round the corner. Also they are so damn expensive. You see that Avatar of shantanu's? That's what you will be doing when you find that the prices have dropped below 5k in another year....
I'm like a bird... :)
06-01-2007, 08:00 AM
Re: blue ray drive
Exactly!
V.Prem Kumar
06-01-2007, 10:40 AM
Romeo + Lucifer = ME
Re: blue ray drive
Prices will definitely drop......so its meaningless going in for a thing @ 50k when in an year u can have it for less than 10k
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
06-01-2007, 10:57 AM
Re: blue ray drive
Also the cost of Blu-Ray media is sky high,it costs 2.5/disc.
06-01-2007, 11:11 AM
Google Bot
Re: blue ray drive
2.5 wat???? n yeah its not worth it to get a blu ray drive now..
06-01-2007, 01:10 PM
Re: blue ray drive
probably 2.5 thousand or something. IT cost around 20$ in the US.
07-01-2007, 10:00 AM
Re: blue ray drive
Its pointless to buy a blue ray drive as its been recently introduced in the market and the prices are pretty high now.
You can wait for a year or so for the pices to drop.
If our keen on the storage space you can go for an external HDD in the similar price range. You can get a lot more storage from it.
Deven
