Old 31-12-2006, 08:14 PM   #1 (permalink)
Default upgrade my hard disk
my comp config:
845gl intel motherboard
2.4 ghz processor celeron
512 ddr ram
i currently have 40 gb harddisk drive
i want to upgrade it ro 200gb
can my computer support it
upgrading harddisk depend upon motherboard or something else?
pls advice me which harddisk i should buy
Ram Agarwal is offline
Old 31-12-2006, 08:30 PM   #2 (permalink)
samrulez's Avatar
Default Re: upgrade my hard disk
yes....but you'll have to find a one with PATA interface.
Sam :D Rulez :lol:
samrulez is offline
Old 31-12-2006, 08:36 PM   #3 (permalink)
whats difference betwwen pata and sata?(is it rpm)
along with the answer plsssssssssssss also post the suggestion which harddisk i should buy
pls help me as i am a noob
Old 01-01-2007, 12:36 AM   #4 (permalink)
samrulez's Avatar
no...not the RPM... both may run at 7200.x.
PATA offers upto 133MB/s...while SATA offers 150MB/s and SATA II offers 300MB/s ....but it doesn't make any sense as an average HDD gives 45-60MB/s...
Sam :D Rulez :lol:
samrulez is offline
Old 01-01-2007, 09:51 AM   #5 (permalink)
dissel's Avatar
First check Is your Motherboard support SATA or not ? I mean do you have SATA port ?
Technical clarification showed by samrulez, But we are home user are hardly found any diffrence between them.
Go for any one of them which your mobo supports
dissel is offline
Old 01-01-2007, 02:10 PM   #6 (permalink)
so finally i can buy 200gb pata harddisk and it will work fine in my computer
y i am asking this because one of my frnd told me that my motherboard will not support more than 137gb?
