30-12-2006, 10:50 PM
How do i decide AMD or Intel
Hey guys could u help me out with this....how do i decide whether i go in for an amd or intel procy???
Im confused between amd x2 and the core 2 duo..now if i go in for an x2 the click spped is high for wht im paying but if i go in for core2duo same amount clock speed is low!! but they say performance is superior..temme ppl how to decide??? wht do i do ..thx!!
31-12-2006, 12:31 AM
Case Mod - 60% ||||||----
Re: How do i decide AMD or Intel
depends on ur usage mate.. lemme know wt ya wanna use it for?
31-12-2006, 02:40 AM
No pain....No gain
What's your budget? And ya C2D is better in terms of performance......don't go just by clock speed.
31-12-2006, 01:03 PM
ill be using it for games,designing,movies,programming,compiling..gues s mostly graphics..and audio video..budget around 7 to 10max
31-12-2006, 04:45 PM
core 2 duo is better if ur gonna make it a ruf usage....dual cores from intel sound better for d time being
Enjoy~!
No Pain...No Gain
31-12-2006, 05:10 PM
amd is the best dude
Enjoy~!
if u want an amd contact me
31-12-2006, 07:22 PM
ANGEL OF DEATH
 buy core2 duo its best and cheaper
| Dell 15z + WD 2TB | | Dell Studio 1555 + WD 1TB | | iPhone 4 32 GB | | Samsung Galaxy S2 White | | Good Desktop Power Of C2D + 4850 |
31-12-2006, 08:26 PM
better maybe but certainly not cheaper! intel is more expensive than AMD
31-12-2006, 08:57 PM
some expert views man!!!!!! this is like a 50 50 thing happening here... pls experts help!!!!!
31-12-2006, 08:58 PM
Go for C2D E6600
31-12-2006, 11:20 PM
Romeo + Lucifer = ME
Its definitely that Intel Core2Duo is better...but then X2 may cost cheaper..
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
31-12-2006, 11:49 PM
If u hav the cash den go for C2D else buy X2.
01-01-2007, 04:27 AM
Learner
lol....
anyhow, it is not possible to provide a definitive answer unless we know your budget, and what you are going to use it for.
For now C2D seems a good option, but we should remember that good LGA 775 motherboards are sky high, again, after launch of c2d AMD has dropped price of X2's uncountably many times, this puts them in real competition with c2d, also considering that we anticipate a longer life of AM2 platform. So basically, when it comes to the final cost/performace/upgradability, either one is not a bad option. Let us know your budget, and what options are you looking at. and then it will be easier to suggest.
01-01-2007, 08:17 AM
01-01-2007, 12:43 PM
Originally Posted by Kniwor
lol....
Hey thnks this is awesome!!! well my budget is about is abt 9k max!!..gonna be using it for home..designing ..programming..games..music vid..n regular stuffs..another option which i was thinking abt is tht if i use 9k i get a higher end x2 but a lower end c2D ..is it more worth takin the c2d now or the x2 considering the performance and my usage!!..Thx i appreciate ur help guys!!!!
01-01-2007, 01:27 PM
I'd suggest u to buy the X2.I'm using X2 3800+ and the performance is gr8.
01-01-2007, 02:44 PM
Learner
A C2D E6300 is better than a X2 4200+, this should give you an idea.
Will you use a seperate vid card or integrated video.
and do you overclock
If you do overclock, and will get a seperate vid card. I'd suggest you get a E6300 with Gigabye GA-965P-DS3.
the combination will cost you around 17k.
If you dont, better get a good AM2 motherboard and processor combination, or you can get an E6300 with some intel G965 if u will not get a seperate graphics card. The whole point is that if u are not going to overclock you can get either, but if u will do moderate overclocking, I'd suggest you get AM2 because your budget will provide you will a decent overclocking mobo, whereas in case of intel, you cant afford a good mobo.
01-01-2007, 09:15 PM
ok this is making sense now thx buddy! just 1 ques..ive heard tht overclocking reduces the life of the procy.how true is tht?? and regarding overclocking...if i do overclick id the cooling on the mobo enough or do i req external cooling??..And is overclocking really safe!!??
01-01-2007, 09:19 PM
#19 (permalink)
Overclocking is safe if u know what ur doing.It does reduce the life of the proccy but not by much.U wont feel it in the long run.My X2 3800+ has a stock spedd of 2GHz and its OCed to 2.5GHz(on stock cooler),and its running witout any probs.
02-01-2007, 12:22 AM
#20 (permalink)
Learner
That is a very debatable issue, overclock in itself is nothing much harmful but you can harm your components in the process of overclocking. Furthermore, i believe that whether or not you overclock, processors outlive their usability. Hence i overclock everything to the max. But it's a very personal choice actually.
About cooling, it depends on the overclock you are willing to do, proper cooling is still costly in India and hence takes away the whole point in getting one. The stock cooling does well if you maintain good airflow in the case. but extreme overclocks do require better cooling.
02-01-2007, 12:31 AM
#21 (permalink)
Rising ApocalypsE
Ok check the link first:
http://xtreview.com/review115.htm
This will give u better idea why C2duo is better than any AMD.E 6600 is almost between $317 & FX-62 $600 is almost the double the price & performance chart is at stock,may be more at overclocking.So grab Core 2 Duo!!!No matter how expensive it is.It will be cheaper than AMD.
02-01-2007, 12:53 AM
#22 (permalink)
Didn't have time to read earlier post, but if you are graphic desingner, serious gammer than go with AMD and if want long lasting system for Office/home/business go with Intel.
02-01-2007, 12:58 AM
#23 (permalink)
Rising ApocalypsE
Buy some time & read this http://xtreview.com/review115.htm
