Old 29-12-2006, 06:54 AM   #1 (permalink)
Default DVD writer - which to buy?
I plan to buy a DVD writer. Which one should i go in for? Is sony's 18X DRU830A fine?
asudevan is offline
Old 29-12-2006, 10:40 AM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: DVD writer - which to buy?
WRONG SECTION=> h/w setion
Its good if u rate SONY products high....else if ur looking for others also then
BENQ> LITEON > SONY...
If interested other than sony will let u know the model nos..else sony drive u selected is also good one
wizrulz is offline
Old 29-12-2006, 11:41 AM   #3 (permalink)
24online's Avatar
sony is fine...also samsung...
try to find with diff.. shops...
24online is offline
Old 29-12-2006, 12:32 PM   #4 (permalink)
GaurishSharma.com
gary4gar's Avatar
for either sony DRU830A or benq 1650
gary4gar is offline
Old 29-12-2006, 01:18 PM   #5 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
No to samsung/Lg ..........................
Buy a Liteon/HP/Sony
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 29-12-2006, 02:21 PM   #6 (permalink)
Still Shining!
Lucky_star's Avatar
I agree to it too.
Samsung and LG are known to cause a hell lot of problems; you can experience once you buy one.
Sony is the best, Liteon is also good
Nokia N86 8MP
Lucky_star is offline
Old 29-12-2006, 02:30 PM   #7 (permalink)
kirtan's Avatar
Liteon is the best i suppose
Water can flow or it can crash.Be Water my friend.
kirtan is offline
Old 29-12-2006, 03:42 PM   #8 (permalink)
I'm d GAME
Lite on is d best.
Don't even think abt samsung its giving me a hell lot of troubles.
sksingh2k3 is offline
Old 29-12-2006, 03:48 PM   #9 (permalink)
Asus 1608ps3 which is actually a Pioneer drive or LG H10N/H12N. If you can find a benq 1640/1650/1655, those are good as well. The newer sony DRU-830A is a samsung rebadge and a pathetic drive. Stay away from it. Stay away from samsungs/liteys/sonys. There are better choices out there. Also don't get carried away by the 18X and 20X or whatever ratings. Finally what matters is write quality if you want to keep the discs for long. Of the drives available in india nothing beats the LG, Benq and Asus in write quality. The Benq is hard to get and the other two are relatively easier.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW.
Ch@0s is offline
Old 29-12-2006, 06:28 PM   #10 (permalink)
yogi7272's Avatar
LITE ON SHM 165P6S ... very good drive ..
also look out for BENQ DW 1640 OR 1650 -
i personally have both LITE ON SHM 165P6S AND BENQ DW 1640 .. both are excellent drives .. also newer lite on drives are very good .. not sure abt the models though...
yogi7272 is offline
Old 29-12-2006, 11:12 PM   #11 (permalink)
Thanks all for the advice!
__________
Can u pls give me Liteon India's website address?
asudevan is offline
Old 30-12-2006, 12:48 AM   #12 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Media Tech provide LITEON>If u r in Mumbai,u wont be having problem because all of their activities run from there or If u r in New Delhi or NCR,LITEON have autorized service centre in Nehru Place.
NOTE:-Only go for that which has service centre in ur city.Things are almost same but optical drives need servicing.SO put it in ur first priorities(SERVICES).
I ''' suggest LITEON or SONY.I have LITEON & its really good.
Samsung & LG....uhhh...
keith_j_snyder2 is offline
Old 30-12-2006, 05:15 AM   #13 (permalink)
Yes go for Liteon or sony
abhipal is offline
Old 30-12-2006, 06:04 AM   #14 (permalink)
dinesh_mettur's Avatar
sony dru 830A with 18x speed is fine and cost is also reasonable
SONY ROCKS !!!!!!!
___________________________
~~ THINK DIFFERENT ~~
.. U'r Ultimate Place To Enjoy ..
www.funisland.co.nr
dinesh_mettur is offline
Old 30-12-2006, 12:13 PM   #15 (permalink)
DigitalImmigrant's Avatar
whether u want with 1 lightscribe or 2 non lightscribe but with DVD RAM or 3 non lightscribe ,non DVD RAM , DVD +- RW only ?
DigitalImmigrant is offline
Old 30-12-2006, 12:18 PM   #16 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
dont confuse him..if he doesnt knows it..he iwll hardly be using it...keep it simple....if he would have specifeid then its okay
wizrulz is offline
Old 30-12-2006, 01:32 PM   #17 (permalink)
Lightscribe with DVD RAM :- Lite-On SHM-165P6S (@3085) >Lite-On SHM-165H6S (@3650)
Lightscribe but NO DVD RAM :- BenQ DW1655 .
No Lightscribe , DVD RAM :- Lite-On SHM 165PS (@2450) > Sony DRU 830A(18x) >Sony DRU 820A(16x)(@2900) > BenQ DW 1650 (@4000)
DVD±RW :- BenQ DW1640 > Lite-On SOHW-1635S(2350) > Sony DRU 810A (basically a rebadged Benq DW 1640 )
MY PICS : Lite-On SHM-165P6S , Lite-On SHM 165PS & Sony DRU 820A , Lite-On SOHW-1635S & BenQ DW1640.
NOTE :
[1] DVD RAM is more suitable to data backups & use in camcorders than DVD +/- RWs.
[2] Lightscribe is an innovative technology tht allows to put a pic of 1s choice (image is in grayscale ) on the CD cover ( requires spcl media ).
Good for personalised labelling , gifts .
[3] Prices of some models (may) hav fallen significantly , n r not latst .
Old 30-12-2006, 01:49 PM   #18 (permalink)
Here's some info for ppl who are recommending that POS Sony DRU-830A ROFL
http://www.techenclave.com/forums/525246-post1.html
Ch@0s is offline
Old 30-12-2006, 03:24 PM   #19 (permalink)
Rising ApocalypsE
Thats just one person...anyone else faces the same?u know not everyone faces same problem,there must be something wrong with this one.If u feel so then read my previous post.
Old 30-12-2006, 04:04 PM   #20 (permalink)
nishant_nms's Avatar
Liteon
nishant_nms is offline
Old 30-12-2006, 05:22 PM   #21 (permalink)
assasin's Avatar
Dont look at the drive's write speed cuz u'll only get 16x DVD media in the market now at cheap rates,just forget bout the '18X' thing.SONY's drives r gr8 but their after sales service sux.
assasin is offline
Old 30-12-2006, 05:42 PM   #22 (permalink)
Commander in Chief
QwertyManiac's Avatar
I'd pick up a Benq 1650/70 or a Pioneer if I can find one.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 30-12-2006, 06:13 PM   #23 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Red face Re: DVD writer - which to buy?
i buy 2 sony dvd writer and both r having same problem.every bootup it make noise and reading is not good then i buyed a smasung dvd writer
Dell 15z + WD 2TB
Dell Studio 1555 + WD 1TB
iPhone 4 32 GB
Samsung Galaxy S2 White
Good Desktop Power Of C2D + 4850
NIGHTMARE is offline
Old 30-12-2006, 06:17 PM   #24 (permalink)
18 Till I Die............
Congrats after one year the samsung drive will give u 'nightmares'. If not then consider that you are one of the luckiest person around.
http://www.bash.org/?258908
mehulved is offline
Old 30-12-2006, 11:12 PM   #25 (permalink)
Majority votes for Liteon. So can someone pls give Liteon's contact address/website?
asudevan is offline
Old 30-12-2006, 11:23 PM   #26 (permalink)
Rising ApocalypsE
Liteon
Company:- MediaTech India
Contact:- 022-26361111
Email:- sales@mediatechindia.com
Web:- www.mediatechindia.com
THere u go....GRAB IT BUDDY!!!
Old 31-12-2006, 12:17 PM   #27 (permalink)
If you really want a good drive then check cdrlabs or cdfreaks or cdrinfo. Majority opinion deciding your purchase is real lame . Also to the person who was shunning that dude... the new Sony DRU830A is *MADE BY SAMSUNG*. Wake up!
Ch@0s is offline
Old 31-12-2006, 07:38 PM   #28 (permalink)
ANGEL OF DEATH
NIGHTMARE's Avatar
Talking Re: DVD writer - which to buy?
READ Ch@Os QUOTE
Dell 15z + WD 2TB
iPhone 4 32 GB
Old 02-01-2007, 07:43 PM   #29 (permalink)
slugger's Avatar
Planning to buy a DVD Writer
Have zeroed in on these two
LiteON LH16A1P Super All Write (Rs.1950)
LiteON SHW1635 S (Rs. 1850)
which one shud i buy and re they gud choices
slugger is offline
Old 02-01-2007, 09:12 PM   #30 (permalink)
both r gud choices . For 100 bucks more u get DVD RAM read/write ability n so I will go with all rite 1 .
Also the latest sony DVD writer SONY DVD RW DW-G120A dual layer writer
is a rebadged LITE-ON SHM-165P6S. So u can che out this 1 also .
DVD RAM is more suitasble for data backups n use in camcorders .
