Old 29-12-2006, 01:12 AM   #1 (permalink)
morpheusv6's Avatar
Default 24x7 PC
I plan to run my PC 24x7.
Could you please suggest whether I should go for a 10k rpm or 7200 rpm hdd?
Deven
morpheusv6 is offline
Old 29-12-2006, 02:22 AM   #2 (permalink)
 Macboy
goobimama's Avatar
Default Re: 24x7 PC
Obviously 7200rpm. Unless, you add a cooler/fan for the HDD which would then make it cool enough to run. But then it depends on what you're going to be doing those 24 hours.... If you NEED the speed....
I'm like a bird... :)
goobimama is offline
Old 29-12-2006, 10:25 AM   #3 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Default Re: 24x7 PC
Speed ------ 10 K RPM
Cool -------- 7200 RPm
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 29-12-2006, 11:09 AM   #4 (permalink)
assasin's Avatar
Default Re: 24x7 PC
Go 4 a 7200rpm hdd.
assasin is offline
Old 29-12-2006, 12:40 PM   #5 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default Re: 24x7 PC
these things does not matter
only matters is thing that proper ventilation & a robust power supply with atleast 400w
gary4gar is offline
