Old 28-12-2006, 06:55 PM   #1 (permalink)
Default My computer is not booting
hi guys,
I have a p4 1.7 ghz machine with 845 motherboard. Whenever i switch on the pc, the boot process does not start. the power indicator becomes on, the harddisk indicator lights up for a couple of seconds and then becomes off. The cabinet fan also is working. The monitor light just keeps blinking.
This happened a couple of times earlier. Then, i just checked for loose connctions in the cabinet and then the pc used to boot. Now nothing happens. What could be wrong?
kishan is offline
Old 28-12-2006, 07:14 PM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: My computer is not booting
Check ur PSU...and then the harddisk....also try changing the CMOS battery
wizrulz is offline
Old 28-12-2006, 07:18 PM   #3 (permalink)
Smile Re: My computer is not booting
Check whether your RAM is properly placed.
Shankar Ganesh is a 16 year old Blogger & Freelance Writer from India. He writes at http://www.killertechtips.com. Gtalk ID - techgurushankar, Skype - shankarganesh91
shankar_ganesh is offline
Old 28-12-2006, 07:19 PM   #4 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
any specific nos of beeps???
wizrulz is offline
Old 28-12-2006, 10:13 PM   #5 (permalink)
jatt's Avatar
first of all plz start your pc without ups and then check if problem still you have to check your power supply plz check it if possible change it with your freinds pc check these then tell me
jatt is offline
Old 02-01-2007, 10:32 AM   #6 (permalink)
@wizrulz
my PSU & harddisk both seem to be fine... and I get no beeps at all.
The power indicator(green light) stays on but the harddisk indicator (red light) becomes off after about 2 seconds.
@shankar_ganesh
My RAM is also properly placed.
I will try to change the CMOS battery and also try out what jatt suggested.
I Will post reply after trying.
kishan is offline
Old 03-01-2007, 11:13 AM   #7 (permalink)
@wizrulz
I changed the CMOS battery but problem remains.
@jatt
problem remains even if i start pc without ups... and the power supply seems to be fine.
Any other suggestions?
kishan is offline
Old 18-01-2007, 05:03 AM   #8 (permalink)
jatt's Avatar
its may be your motherboard problem check that if possible
ਨੋ ਗਰਲ ਫਰੈਂਡ ਨੋ ਟੈਂਨਸ਼ਨ,no girlfriend no tension,website: Punjabi.c-o.in,forum: punjabiteacher.co.cc
jatt is offline
