Old 28-12-2006, 04:26 AM   #1 (permalink)
kumarmohit's Avatar
Default Connecting LAptop to Desktop using USB cable
OK Guyz
I have a Desktop and a Laptop, both have a free USB2.0 Port. And I have a USB cable with both A type connectors. I want it to make a network of Laptop and Desktop. Both run WinXP SP2, Desktop has XP Home < Laptop has XP Pro. Can any one tell me if its possible and if yes the steps too...
PS. Desktop has a LAN card to run SIFY net. I hope there will not be IP conflict issues.
kumarmohit is offline
Old 28-12-2006, 08:01 AM   #2 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Default Re: Connecting LAptop to Desktop using USB cable
The easiest way to connect a laptop and a desktop pc is through lan wire.
Get a lan wire with cross connection(tell the vendor to make it cross).
Plug in both the wires and go to the My Network Places.
Click on setup Home or small office network.
Well if u want to connect through Lan i will provide you with the detailed procedure.
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 28-12-2006, 10:13 AM   #3 (permalink)
Before you attempt to connect 2 computers with a regular USB cable read this...
http://www.hardwaresecrets.com/article/248
suman2005 is offline
Old 28-12-2006, 10:18 AM   #4 (permalink)
kumarmohit's Avatar
The problem is that I will have to buy a new Lan Card which will fill up the desktop's only free PCI slot
@Suman -- So can I get this bridge cable in Delhi?
Old 28-12-2006, 10:55 AM   #5 (permalink)
Old 28-12-2006, 12:10 PM   #6 (permalink)
Google Bot
Pathik's Avatar
@kumar.. .wich mobo d u hav????
mebbe it might hav onboard ethernet adapters..
Pathik is offline
Old 29-12-2006, 12:36 AM   #7 (permalink)
-- No Easter Eggs here --
hemant_mathur's Avatar
U can network through usb cable but it's a special type of usb cable which has some circuit (or something) in the center. They are available at Nehru Place, New delhi.
But those cables are currently available in usb 1.1 only.
E6850 3.0 Ghz, 4gb 667 Mhz RAM, Asus p5n Esli Mobo, Nvidia 8600GT 512mb, 400gb WD HDD, Samsung Syncmaster 920NW, Vista x64
hemant_mathur is offline
