| Forum |
#1 (permalink) |
mortal kombat
well i need a graphix card that has 256mb memory and supports shader model 3.0 shader units 8-12 memory bandwidth 128. or else a card which is cheap on which and i can play splinter cell chaos theory smoothly at its lowest settings. well if there is any such card please mention. well my budget is max 5k. |
#4 (permalink) |
Romeo + Lucifer = ME
In your budget:
7300Gt 4.5K ATi X1350 3.8K Just over budget: 7600 GS DDR3 Rs5800 X1600XT Rs5500
Sony Vaio CW26FG Nokia E 63 + Iphone 3GS Nikon D3000 + 50mm f/1.8 + 70-300mm Lens |
#5 (permalink) |
Rising ApocalypsE
X1600XT for 5500?Where did u get these prices romeo?& which brand is this?
And for u Quan Chi: Just wait for DX10 based low-mid end GPU's.I believe till march 2007!!!But if u don't wanna wait,then go for any DDR3 GFX card.
AMD Athlon 3200+,MSI RS482M4-ILD,Kingston KVR 512MB 400,Gainward 6800GS 256MB,250GB WD Caviar,Cooler Master 430Watts. Last edited by keith_j_snyder2; 28-12-2006 at 12:13 AM. |
#7 (permalink) |
Rising ApocalypsE
I don't think LEADTEK make ATi cards,its nVidia based buddy,must be something wrong!!!
Just send me any link for leadtek Ati card.
AMD Athlon 3200+,MSI RS482M4-ILD,Kingston KVR 512MB 400,Gainward 6800GS 256MB,250GB WD Caviar,Cooler Master 430Watts. |
#8 (permalink) |
Try me
i am really very sorry to say but WE are selling leadtek and MSI brands in ATi chipsets at our shop..
didnt have a link for it ... and msi costs rs. 6700/-
Forum rules: http://www.thinkdigit.com/forum/announcement.php?f=3 Blog at : http://thecomputernext.com/blog |
#9 (permalink) |
Rising ApocalypsE
Is it a joke,is it home made card!!!Dude i m googling around & i m not able to find LEADTEK X1600XT.If leadtek make any of Ati's card,there must be somewhere on the web.
Ok if u r saying that u have the cards then whats the price of X1800GTO & XL. Please give me ur address,i m sure i 'll definetly buy graphics card from u...probabely X1800GTO.
AMD Athlon 3200+,MSI RS482M4-ILD,Kingston KVR 512MB 400,Gainward 6800GS 256MB,250GB WD Caviar,Cooler Master 430Watts. Last edited by keith_j_snyder2; 28-12-2006 at 01:29 AM. |
#11 (permalink) |
Rising ApocalypsE
Absolutely!!!Any graphics card which has DDR3 RAM works fine.If u choose DDR2 then also it will work on lower resolution.But i suggest choose wisely & only DDR3 ,if u want to run games smoothly even on 1280X1024.
6600 GT is good but go for 7600GT instead of 6600GT.6600 was also good card but now it has been overpowered by 7600!!!
#13 (permalink) |
18 Till I Die............
Well 7600GT will be way out of your budget. It will cost around 9-10K. 7600GS is somewhere around 5.5-6K and should be good for you. And NFS MW demo was running fine at 1024x768 though I found 800x600 more preferable.
http://www.bash.org/?258908 |
#14 (permalink) |
Rising ApocalypsE
i have 6800 GS & i play NFS MOST WANTED on everything MAXX. & i never saw any low frame rate on it...so far,it's an AWESOME card 7600 is better than 6800 GS but the only advantages of 6800 is bandwidth & 256 Bit.
#15 (permalink) |
Make Way the LORD is Here
7600 gs or ati 1600xt or pro
these r the cards u should go for
And On the 6th day, God created MANchester united ![]() (Gen.1:26-27) New Testament FORUM RULES - Updated Don't Buy from Sulekha |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
