Old 27-12-2006, 03:21 PM   #1 (permalink)
Default Flsh drive cannot be formatted..pls help
I can't write any files to and delete any files from my 1GB flash drive. Even i cannot format. it says"disk is write protected.." . This has happened just 2 days back.It was proper before.Is there any way I can get this problem solved?
getyourjayaram is offline
Old 27-12-2006, 03:25 PM   #2 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Default Re: Flsh drive cannot be formatted..pls help
Try the software provided with your flash drive to format it.
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
