Old 27-12-2006, 01:06 PM   #1 (permalink)
Default Best UPS
*What is the cheap and best 700VA UPS? My budget is Rs.2000/=or something more.
Model number and price along with some details of the UPS?
kumarn_2004 is offline
Old 27-12-2006, 03:16 PM   #2 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Default Re: Best UPS
Well i am using a Microtek ups for the past 5 years n not faced a single problem
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 29-12-2006, 07:45 AM   #3 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
im ussing a classic no problems for 4 years
apc ups r supposed to be very good
(Gen.1:26-27) New Testament
FORUM RULES - Updated
Don't Buy from Sulekha
ssk_the_gr8 is offline
Old 29-12-2006, 11:11 AM   #4 (permalink)
assasin's Avatar
Either go 4 an APC or ITeon (produced by Libert).Both r good but ITeon will be costlier and better.
assasin is offline
Old 29-12-2006, 12:20 PM   #5 (permalink)
The Devil
blackpearl's Avatar
Actually there is nothing called a best UPS. They are the most unreliable and unpredictable. I have seen Microtek UPS run for both 5-6 yrs as well as less than 6 months. Some nameless brand can run for years without problems while even APC can break down after 1 yr, as it happened to one of my friends.
blackpearl is offline
Old 29-12-2006, 06:28 PM   #6 (permalink)
^^^ I agree - but the UPS with a very good reputation is this model of APC. Supposedly a better model then the other UPS's available locally .... I dont have a price but I have heard it is a little expensive...
http://www.apcc.com/resource/include...CountryCode=in
suman2005 is offline
Old 29-12-2006, 06:32 PM   #7 (permalink)
yogi7272's Avatar
I am using apc 600 va ups for the last 4 and 1/2 years .. without any prob whatsoever ..
yogi7272 is offline
