Old 26-12-2006, 11:15 PM   #1 (permalink)
antoniobc's Avatar
Exclamation System performance
I have a D-Link motherboard (around 3 years old) supporting a 1.2Ghz Celeron Processor and 256 MB SD Ram! HAve a 40 GB IDE HDD! How can I improve its performance with respect ti
1) Hardware (Not too expensive since money is a prob)
2) Software (with respect to OS's etc... but I want to run hi-fi stuff on it: Egs MS Office 2007 etc.......)
Was considering addin 128 MB Ram and installng XP but still havent made a decision of Home Edition vs Professional! Its a PC not networked so I dont really knw in wat way Professional will benefit me! Also I'm started my course in Computer Engineering so I need performance boosts!
In general I need a computer makeover!
HELP!!!!!!
antoniobc is offline
Old 26-12-2006, 11:21 PM   #2 (permalink)
Try me
shantanu's Avatar
Default Re: System performance
If you have 1500/- then increase your RAM to 512 means 256 current and 256 more and then choose XP PRO SP2 will be best for you system..
Forum rules:
http://www.thinkdigit.com/forum/announcement.php?f=3
Blog at : http://thecomputernext.com/blog
shantanu is online now
Old 27-12-2006, 07:09 PM   #3 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Increasing ram will solve most of your speed problems..................
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 27-12-2006, 07:12 PM   #4 (permalink)
Tech Geek's Avatar
incresase it to a 1GB ram. better
Tech Geek is offline
Old 27-12-2006, 07:14 PM   #5 (permalink)
People buy the best of processors but forget the importance of ram in the normal running of the machine.........
Sony Vaio CW26FG
Old 27-12-2006, 10:14 PM   #6 (permalink)
assasin's Avatar
get urself more RAM,and if ur mobo has AGP slot think bout getting and AGP crd.
assasin is offline
Old 27-12-2006, 11:01 PM   #7 (permalink)
Try me
shantanu's Avatar
YA GET a GFX IF POSSIBLE
Forum rules:
Old 27-12-2006, 11:13 PM   #8 (permalink)
Ig your budget permits then GFX n RAM will get you all the way
Sony Vaio CW26FG
Old 28-12-2006, 08:30 PM   #9 (permalink)
dOm1naTOr's Avatar
but u might have hard time getting a 256 SD now a days. Try to get even a second hand one.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 29-12-2006, 12:26 AM   #10 (permalink)
nishant_nms's Avatar
Get atleast 256 MB of RAM
nishant_nms is offline
Old 02-01-2007, 01:00 AM   #11 (permalink)
antoniobc's Avatar
Dont have dat much cash dudes! Got my friends 128 Megs of SD! So my total is now 392 or something! Wat else can I do?
Old 02-01-2007, 01:19 PM   #12 (permalink)
assasin's Avatar
Get urself a GFX card if ur mobo has AGP slot.Buy a nVidia 6200 256MB atleast
assasin is offline
Old 03-01-2007, 12:08 PM   #13 (permalink)
antoniobc's Avatar
Lightbulb Re: System performance
I should have made this clear:
The motherboard supports:
2 DIMM slots : 512Megs per dimm
3PCI
NO AGP slot
2IDE
810E Chipset
Thats basically it!
I dont want to upgrade it with respect to its RAM right now cause I dont have the cash! Like I said before it have 392 MB RAM (SD)
So maybe on the lines of an OS or BIOS tweeks or something of the sort!
Old 03-01-2007, 10:28 PM   #14 (permalink)
assasin's Avatar
If u can get urself a PCI gfx crd.Deres nothing much dat u can do thru bios or OS.
assasin is offline
Old 04-01-2007, 02:36 AM   #15 (permalink)
rajasekharan's Avatar
All you can do is put windows on classic looks . . Defrag the hdd ,run reg cleaners like tuneup. . Increase the page file to 1mb more than your ram
Make a day good , and another day good , and another ...a happy lad is "born" from you
rajasekharan is offline
Old 04-01-2007, 09:43 AM   #16 (permalink)
piyush gupta's Avatar
Either buy new RAM of put your system in a high performance mode
u can also use tweaks
autopatcher
tune up utilities
to increase ur system performance
piyush gupta is offline
