Old 25-12-2006, 05:51 PM   #1 (permalink)
Default Proc Pin Broken...
Ok..F*** me, I know. I tried to experiment on my old **** P3 and broke some pins, I want that damn thing runnin' any suggestions?
Geeks101 is offline
Old 25-12-2006, 06:04 PM   #2 (permalink)
18 Till I Die............
Default Re: Proc Pin Broken...
Please post in right sections and mind your language.
http://www.bash.org/?258908
mehulved is offline
Old 25-12-2006, 06:10 PM   #3 (permalink)
Yeah i would. Fresh Stock dude.
Geeks101 is offline
Old 25-12-2006, 06:25 PM   #4 (permalink)
samrulez's Avatar
Ask your dad to give you cash to get a new one... .....Sorry...nothing can be done...you won't be also to RMA it...
Sam Rulez
samrulez is offline
Old 25-12-2006, 06:26 PM   #5 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Cool if u r fresh stock it gives you the liberty to use filthy language......
Anyways wat exactly is your problem please specify
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 25-12-2006, 07:01 PM   #6 (permalink)
The Unknown's Avatar
Which Pins have broke? Tell in detail
KDE on ArchLinux
The Unknown is offline
Old 25-12-2006, 09:22 PM   #7 (permalink)
Try me
shantanu's Avatar
there are some ways by which proccessor can run after some pins broken also but this not implies if you broke 10-20 pins can only work on some 1 or 2 pins and thats too on the montil memory controller means on the cache side..
so tellt he right dimensions and by placing the processor with pins up on a soft surface and calculate the pins from your left to right and then tell which sided and how many and pins no. too ... BUT ITS BETTER TO GET A NEW ONE COZ IT WONT PERFORM WELL !!! CAN COZ SERIOUS PROBLEMS TO MOTHERBOARD TOO ..
AND USE GOOD LANGUAGE IN THE FORUM...
Forum rules:
http://www.thinkdigit.com/forum/announcement.php?f=3
Blog at : http://thecomputernext.com/blog
shantanu is offline
