Old 25-12-2006, 02:29 PM   #1 (permalink)
Default TataSky with TV Tuner
Hey all
does this tatasky or dishtv work with our internal/external tv tuner cards??
any experience??
I\'M BACK
khandu is offline
Old 25-12-2006, 04:00 PM   #2 (permalink)
Chillum Baba
a_medico's Avatar
Default Re: TataSky with TV Tuner
Nice query. Therotically it should. You will still need tata's setopbox and remote anyway. surfing channels will be from tata's remote and not from keyboard/mouse.
Its just my assumption though. Would like to see what others say.
a_medico is online now
Old 25-12-2006, 04:55 PM   #3 (permalink)
pra_2006's Avatar
hey man i also want to know this i have Pinnacle PCTV PRO card will this work in my TV Tuner?
pra_2006 is offline
Old 25-12-2006, 07:19 PM   #4 (permalink)
well i called tatasky helpline and they said it will..
But any takers here?? cause software will be of the the tv tuner card i guess to view the TV..
awaiting more response.. even from DIshTV ppl...
I\'M BACK
khandu is offline
Old 27-12-2006, 12:20 AM   #5 (permalink)
Just a guess...the TV Tuner software scan may find only one active channel..i.e. whatever is coming from the Setopbox.
patkim is offline
Old 27-12-2006, 12:49 AM   #6 (permalink)
assasin's Avatar
^^^ U need to connect the set top box with ur tuner card with the help of a composite cable( connect to composite input of tuner card) and the connect the audio cable to line in of tuner card.
For Pinnacle TV Tuner card user:connect the audio cables from set top box to the audio Line-In port of ur mobo.
assasin is offline
