Old 25-12-2006, 08:35 AM   #1 (permalink)
pritish_kul2's Avatar
Red face Cd - Rom
MY cd rom opens after 6- 7 tries and when the cd is loaded and when i try to open the rom again then it opens on the first try.
pritish_kul2 is offline
Old 25-12-2006, 08:51 AM   #2 (permalink)
Still Shining!
Lucky_star's Avatar
Default Re: Cd - Rom
Do you have a Samsung Drive. I had opened up a friend's CD drive which had a similar problem. After oiling some parts and cleaning out the dusts, it ran fine for few days. Now it is again the same.
Nokia N86 8MP
Lucky_star is offline
Old 25-12-2006, 01:05 PM   #3 (permalink)
digiFriend's Avatar
now that is old age problem. now always keep a cd in cd-rom.
you never know what you can do until you try
digiFriend is offline
Old 25-12-2006, 01:14 PM   #4 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Ya digiFriend is right. Always keep a CD in ur CD-ROM & it is much better if u keep a transparent CD (without media) in CD-ROM.
Minds are like Parachutes They work best when open
n2casey is offline
Old 25-12-2006, 09:25 PM   #5 (permalink)
Try me
shantanu's Avatar
or keep the sample disc or protect disc which comes on the top and bottom of every 10 25 50 and 100 cd packs you can get it from any local media sellers... thats the best for the job
Forum rules:
http://www.thinkdigit.com/forum/announcement.php?f=3
Blog at : http://thecomputernext.com/blog
shantanu is offline
Old 26-12-2006, 09:01 AM   #6 (permalink)
thanks a lot, all of u
Old 26-12-2006, 11:12 PM   #7 (permalink)
Try me
shantanu's Avatar
its ok buddy !!! OUR PLEAsuRE
Forum rules:
shantanu is offline
