| Forum |
#1 (permalink) |
Unless you have a dream, you are not going to achieve anything in life. Shoot for the moon, even if you miss, youll fall in the stars. ******************ÏMPÕ§§ÏßL£ ϧ ÑÕTHÏÑG ****************** |
#2 (permalink) |
I would suggest u to upgrade ur speaker first to 5.1 then to get a sound card if ur budget permits. I am assuming ur onboard audio supports 6 channel audio as u have not posted ur PC specs
AMD Athlon64 2800+|ASUS K8N-VM|2GB DDR400|Corsair VX450|Seagate ST3500320AS|Samsung SV0411N|LG 22xDVDRW|LG 700S|APC ES500|Altec Lancing AVS300|Logitech MX3200|Logitech QuickCam Connect|Philips SHM6105 |
#4 (permalink) |
thanks for the tips but i need a 2.1 crd.. there are many good options for 5.1.. but the problem is with the 2.1 card..
#5 (permalink) |
Any 5.1 card could work as 2.1 nd nowadays no 2.1 cards are available. Also U can't notice the difference in sound on value creative 2.1 speakers like inspire nd SBS. It should be min of a 5.1 .
G1: PII X4 B50 4.0 | TRUE 120*2 | TA790GXB A2+ | 4GB DDR2 GSkill 1200 | Audigy 2 | HD4870 | HEC 550 | MX 518. G2: AII 240 | M2N 68AM+ | 3GB| 8800GT | Zebby Plat 500 G3: XPS M1530 | FZ 16. Last edited by dOm1naTOr; 25-12-2006 at 11:36 AM. |
#6 (permalink) |
For your 2.1 speakers, the onboard 5.1 soundcard should be sufficient... With these two, mostly the speakers will be the performance bottleneck. If you want to improve the quality of sound from the set, you should consider upgrading the speakers before purchasing soundcard.
Arun |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
