| Forum |
#1 (permalink) |
who cares...
#2 (permalink) | |
GUNNING DOWN TEAMS
So if u r ready to compromise then do it.... better sell ur 266 Mhz stick and but two 512 or two 256 400Mhz ...that will serve u better
The moment U stop learning ......u stop improving |
#3 (permalink) |
bro listen, ur 512 mb ram wil work if it wil be of 266mhz otherwise not.
n if u want to upgrade ur ram thn buy another 256 mb coz if u wil buy other than 256 thn it wil consume different voltage n u wil nt get the boost. another option sell 256 n buy 512. |
#4 (permalink) |
It will work,but not at 4oo mhz.Also sometimes due to mismatch freqency there can be problems.Preferably use both the ram sticks from the same manufacturer & of same freqency.
#5 (permalink) |
Romeo + Lucifer = ME
See it is best that both the ram modules are of the same chipset, same memory size n of the same company to avoid any conflicts
Sony Vaio CW26FG Nokia E 63 + Iphone 3GS Nikon D3000 + 50mm f/1.8 + 70-300mm Lens |
#6 (permalink) |
Do not think any more go and buy them they will definetly work.
AMD Athlon64 2800+|ASUS K8N-VM|2GB DDR400|Corsair VX450|Seagate ST3500320AS|Samsung SV0411N|LG 22xDVDRW|LG 700S|APC ES500|Altec Lancing AVS300|Logitech MX3200|Logitech QuickCam Connect|Philips SHM6105 |
#7 (permalink) |
who cares...
Thanks for the reply.
But i am confused with the answers. If i use 512MB 400MHz ram stick with 256 MB 266Mhz , except for compromising for speed is there any other prob which i will face. |
#9 (permalink) |
I already told u to get the new RAM
| Bookmarks |
| Thread Tools | |
| Display Modes | |
