Old 22-12-2006, 07:21 PM   #1 (permalink)
Tech'ing life seriously!!
sude's Avatar
Exclamation Upgrade queries...
my current system configuration is P4 1.7Ghz on Intel D845GLAD M/B having 128Mb DDR RAM and a 40GB HDD.
Firstly, i plan to upgrade it with a new AMD processor (specifically AM2) and a compatible motherboard, 512Mb of RAM and a 80GB SATA HDD. Please recommend a suitable AMD processor, motherboard and which HDD and RAM Brand to go for. I would be using the PC for multimedia viewing, a little video and photo editing and casual gaming. I live in Bangalore so if possible please mention the individual prices for each component as in bangalore (ie, AMD Processor, m/b...and so on)
Secondly, i heard that AMD Motherboards donot have integrated graphics so does that mean that i have to buy a Graphics Card for viewing. If so please mention the name and Price of an good entry level graphics card having atleast pixel shader 2 because i heard that newer games require atleast pixelshader 2. The graphics card may or may not lie in my budget (ie, Rs.15000).
-Aaditya (SUDE's Friend)
Hi! Any1 pursuing PG from SCDL (Symbiosis Distnce Learnin) frm Bangalore? If yes PM me. We cn form a study group (on weekends). Ths wil b mutually beneficial!
Rgds. SUDE | www.lifeethiquette.co.nr
sude is offline
Old 22-12-2006, 07:35 PM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: Upgrade queries...
Firstly wrong section=> h/w section
Ur an older member...please do post in correct sections
Athlon64 3000+ AM2 3.6k
Asus M2N-MX 4.3k
512 MB DDR2 RAM 3k
80GB SATA2 HDD 2.3k
This mobo has onboard graphics......
For mobo info
http://www.asus.com/products4.aspx?l...38&modelmenu=1
wizrulz is offline
Old 22-12-2006, 07:41 PM   #3 (permalink)
Tech Geek's Avatar
Processor-->Athlon 64 3800+ (64-bit,2.4GHz,512KB L2 cache,2GHz HT bus,AM2 and 939) Rs4800
Motherboard--> ASUS M2V-TVM Rs3200(AM2)
RAM-->TRANSCEND 512 MB Rs2700
Hard disk-->Seagate 80 GB (7200 RPM) Rs1950
Tech Geek is offline
Old 22-12-2006, 08:59 PM   #4 (permalink)
assasin's Avatar
Athlon 64 X2 3600+ & Asus M2N-MX = 10k
512MB Ram = 2.7k
80GB 7200RPM HDD = 2k / 160GB 7200RPM HDD = 3k
Nvidia 6600LE = 4k
7300GS = 3.3k
6200TC = 2.2k
assasin is offline
Old 22-12-2006, 09:23 PM   #5 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
512MB Ram = 2.7k
Nvidia 6600LE = 4k
7300GS = 3.3k
6200TC = 2.2k
his budget is itself 15K and so scope of added graphics card
wizrulz is offline
Old 23-12-2006, 06:30 PM   #6 (permalink)
sude's Avatar
sorry pals i wud have posted in qna section and thanks for the help..
-SUDE
sude is offline
Old 23-12-2006, 08:48 PM   #7 (permalink)
nishant_nms's Avatar
many AMD boards have onboard graphics and many of them esp. from nVidia and ATI are much better than the Intel onboard ones
nishant_nms is offline
Old 23-12-2006, 09:05 PM   #8 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
If u dont want to buy a graphics card then buy a motherboard with Nvidia 6150 or ATI X200 onboard card
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
