Old 22-12-2006, 06:29 PM   #1 (permalink)
Default Northbridge Cooler...Help!!!!
My ASUS A8N-SLi Deluxe Northbridge fan seems to be failing? It dosent seem to run properly? Can any of you help me get a Zalman ZM-NB47J Northbridge cooler or anything for the chipset? i live in Hyderabad? PLz Help!!!!!
panzer is offline
Old 23-12-2006, 07:21 AM   #2 (permalink)
Default Re: Northbridge Cooler...Help!!!!
the only way to get zalman products in India is to import from places where they sell.. i did try through the zalman reseller here in india.. but they arent into any cooling products yet.. however if you do want it.. you would have to rely on friends/family who are returning to India.. i got mine in this way.. all i needed after that was a good fan blower to improve air flow through the cabinet.. gd luck
da_tcpip is offline
Old 24-12-2006, 09:42 AM   #3 (permalink)
Thx. I have frenz in the US and UK. will try thru them.
panzer is offline
Old 28-12-2006, 02:54 AM   #4 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
U can try Cooler Master products also & they are available in INDIA.
keith_j_snyder2 is offline
Old 28-12-2006, 08:03 AM   #5 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Zalman has to be imported from US or Uk.
While Cooler Master Products are available in India and provide equally good performance
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
