Old 22-12-2006, 04:01 PM   #1 (permalink)
pra_2006's Avatar
Question Need Help in Buying New Processor & MOBO
hi friends i am from New Delhi i want to buy a new system for most Gaming and DVD movies and i am thinking of buying - Intel Pentium D 945 3.4Ghz Dual Core 800MHz FSB 4MB L2 Cache LGA 775 EM64T Processor and Intel DG965RY Motherboard with Core2Duo Support i want to know will this MOBO support DX10 PCI-E Graphics cards like 8800 GTX for future pls reply me fast
pra_2006 is online now
Old 22-12-2006, 04:25 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Need Help in Buying New Processor & MOBO
wats ur budget????
n drop the pentium d n take a conroe e6400...
Pathik is offline
Old 22-12-2006, 04:30 PM   #3 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Specify the budget...............
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 22-12-2006, 04:32 PM   #4 (permalink)
My question is: If you can afford 8800GTX, can't you cough up couple more grand and get a Core2Duo E6300? Get the C2D and you will never regret it.
__________
Buy only from following Conroes: E6300, E6600 or E6700. The other two(E6400 and E6800) don't give enough returns for the extra price.
Core2Duo E6600, Asus P5B Deluxe WiFi, Transcend 1GB DDR2533, BIG 7600GT 256GDDR3, Seagate 250GB SATA2 3GB/s, Primo TV Tuner, Creative Audigy 2, Samsung 19" 940BW, Antec SLK3000B + 400w SmartPower.
Maverick069 is offline
Old 22-12-2006, 04:46 PM   #5 (permalink)
a_g = JPKN
s18000rpm's Avatar
regarding the c2d processors, if you can wait till second half of 2007, you can get the same proccy @ some cheaper rate.
__________
does Intel DG965RY Motherboard or any other intel m/b have onboard/in-built WiFi
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 22-12-2006, 07:44 PM   #6 (permalink)
pra_2006's Avatar
thats why i am buying pentium d 3.04 with 965 mobo , when the price of c2d will slash then i will buy it right now its so much costly and i dont want to buy 2.13 its about 11000 and c2d will support 965 mobo and pls tell me will directX10 support DG965RY Motherboard
Old 22-12-2006, 08:01 PM   #7 (permalink)
sumeet singh's Avatar
Question Re: Need Help in Buying New Processor & MOBO
by the way can anyone tell me wat will be the price of the configuration mentioned in first post...
sumeet singh is offline
Old 22-12-2006, 09:02 PM   #8 (permalink)
Just another linux lover.
subratabera's Avatar
I want to know one thing here. Are all C2D processors have 64bit architecture??? If yes, then what would happen with our current 32bit applications (this includes OSs also, such as WinXP, Linux etc.)??? Will they run taking the full advantage of dual cores??? Please share your views....
Today is a most unusual day, because we have never lived it before; we will never live it again; it is the only day we have.
(Registered Linux User #432737 - subratabera.blogspot.com)
subratabera is offline
Old 22-12-2006, 09:17 PM   #9 (permalink)
a_g = JPKN
s18000rpm's Avatar
965ry is dx10 upgradable. (not 100%).
then again in Q2 2007, DX10 chipset from intel is arriving. read more about it here
but as far as gaming is concerned, you have to get a dedicated gfx. card, coz GMA x3000 is NOT gaming card & talking about nvidia 8800, the price is astronomical. for the mid-low end DX10 card, you'll have to wait till 1st quarter of 2007.
Old 23-12-2006, 02:17 AM   #10 (permalink)
pra_2006's Avatar
okay then i will wait for next year becauz i want a good future system which can support DX10 games easily and i will also make my pocket much heavy right now i have 20000 i think i have to get 20000 more thanks for ur replies
Old 23-12-2006, 10:07 AM   #11 (permalink)
a_g = JPKN
s18000rpm's Avatar
To Play DX10 games, according to this news DirectX 10 will not take off until 2nd Half 2007, says AMD, you'll have to wait till 2nd half of next year.
Old 23-12-2006, 04:34 PM   #12 (permalink)
pra_2006's Avatar
oh man thats bad news but till then i will buy all directX10 hardware needs
