Old 22-12-2006, 03:04 PM   #1 (permalink)
Question how to connect pc to tv
i want to connect my pc to my tv, i have onida tv, pls tell me how can i do it and how much will it cost me , i do not want to spend too much amount.
nikunj
nikunj is offline
Old 22-12-2006, 03:06 PM   #2 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
Default Re: how to connect pc to tv
Donno the procedure but ur TV will not give u as much resolution as needed for computers specially for text.
n00b forever...
~Phenom~ is offline
Old 22-12-2006, 04:23 PM   #3 (permalink)
You would need a TV-Tuner, or atleast a Gfx card that has AV-out. And yes Phenom is right.
Core2Duo E6600, Asus P5B Deluxe WiFi, Transcend 1GB DDR2533, BIG 7600GT 256GDDR3, Seagate 250GB SATA2 3GB/s, Primo TV Tuner, Creative Audigy 2, Samsung 19" 940BW, Antec SLK3000B + 400w SmartPower.
Maverick069 is offline
Old 22-12-2006, 07:12 PM   #4 (permalink)
it is good for watching movies of playing sport games with a wireless gamepad
XtraOrdinary is offline
Old 23-12-2006, 02:25 AM   #5 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
do you want to watch TV on your computer monitor or connect your cpu to your TV screen?
For the first simply get a Tv-tuner card or a graphics card with that av-thing. Note that as such your TV won't come into play if all you want to do is watch TV 'in' your computer, you just have to attach the cable wire into the tv-tuner card.
chesss is offline
Old 30-12-2006, 07:57 PM   #6 (permalink)
DigitalImmigrant's Avatar
a detailed tut is beyond me . check out CHIP magazines Dec. issue . It hasc a detailed n illustrated article on this with the pros n cons . What ~phenom~
said earlier is true !
DigitalImmigrant is offline
Old 30-12-2006, 08:51 PM   #7 (permalink)
Arsenal_Gunners's Avatar
most tv tuns and gfx cards have tv out cables.by using them you should be able to do this
Arsenal_Gunners is online now
