Old 21-12-2006, 05:16 PM   #1 (permalink)
Question Solve it ,Tv Tuner problem
Hello guys,
can anybody solve my problem? I have a pc with intel 865gbf motherboard,
onboard graphic, creative 5.1 de sound card and internal intex tv tuner card,os is windows xp pro Sp2 and i use Windvr to capture tv programe, now days my tv tuner card not show anything it show only a blank screen and nothing happening i also try to reinstall the hardware but the problem is same but when i try attech the card into my friend pc it work fine.
can anybody suggect me where is the problem is my motherboard is foulty or Ram or any other hardware failure or software issue ?
Thanks
sac_meer is offline
Old 21-12-2006, 09:52 PM   #2 (permalink)
assasin's Avatar
Default Re: Solve it ,Tv Tuner problem
Did u try installing the tuner crd in a different pci slot in ur mobo?
assasin is offline
Old 27-12-2006, 03:58 PM   #3 (permalink)
Yes i try it but same problem !
sac_meer is offline
Old 27-12-2006, 05:33 PM   #4 (permalink)
Arsenal_Gunners's Avatar
if it is not a hardware conflict
1.check the source setting in windvr (tv ,sv etc.)should bet tv(sv causes black screen)
2.if 1 not works reinstall windvr.
3.if 2 not works check your cable connection to pc by bringing a tv there.
4.if none of them work try some other pvr software.
5.if any of them work please repute me
Arsenal_Gunners is online now
Old 27-12-2006, 09:26 PM   #5 (permalink)
Can you hear any audio when the screen is blank..or is it totally dead.
What happens if you increse / reduce the volume? Does it show any volume indicator on screen?
patkim is offline
