Re: Best 478 Mobo avilable in Market..
If you are lucky you will get an 865 based board. Otherwise, you will have to settle for 845. Those are the your only choices. If you go in the market, you will at max have the luxury of a couple of manufacturers to choose from for these. If theres just one, the decision would be simpler. So, I think you should stop searching for other alternatives. May be, think of an upgrade altogether.
