Old 19-12-2006, 12:20 PM   #1 (permalink)
gsmsikar's Avatar
Default Empty DVD R media 8.5GB
can anyone tell me what is the lowest price of Empty DVD R 8.5GB media?
what is the price in loose packing and in box packing ?
gsmsikar is offline
Old 20-12-2006, 10:11 AM   #2 (permalink)
harikatt's Avatar
Default Re: Empty DVD R media 8.5GB
it can be 20-50Rs,, but which company. do u have..
since and 4.7gb one is around 10-12Rs..
3d Graphics Animator, //\\ Senior level team Leader
Life is so deep,, that if we try to see in it, we may fall ourselves
harikatt is offline
Old 20-12-2006, 10:27 AM   #3 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
but is it yet available in India?
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Old 20-12-2006, 11:09 AM   #4 (permalink)
@gsmsikar: wrong place for the thread
@harikatt: not cheap as u think,Verbatim which is rated as Best dual Layer media sells around 180 with casing,sony 240
@gauravakaasid: Yup available,Not as Spindle only as Single casing
vinyas is offline
Old 20-12-2006, 11:11 AM   #5 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
he doesnt has it..he wants info....so this in WRONG SECTION...
and not so cheap...else everyone would had prefered these instead of 4.7gb variant
P.S.==OOPS vinyas also did say same
wizrulz is offline
Old 20-12-2006, 11:32 AM   #6 (permalink)
gsmsikar's Avatar
@vinyas
that is what i wanted to know , as i was also asked rs190 for a 8.5gb dvdr media in the market ,
and i thought it could be near aroung rs 30 to 40
thanks
gsmsikar is offline
Old 20-12-2006, 11:41 AM   #7 (permalink)
harikatt's Avatar
dude.. DVD r is for only onetime writing data.. thats all and DVD rw is the costly.. like 150 - 200Rs .. so feel the difference and find it ..
DVDr of 4.7 or 4.3 or 8gb type are less in cost.. and can be near or below Rs 50..
harikatt is offline
Old 20-12-2006, 12:38 PM   #8 (permalink)
Sony Dual layer DVD (8.5 Gb) media costs Rs. 400 per piece in Bangalore. It is available in very few outlets.
vikz is offline
Old 20-12-2006, 12:49 PM   #9 (permalink)
Check This:
http://www.computerwarehousepricelis...ist.asp?ctg=34
http://cgi.ebay.in/Mitsubishi-Blank-...QQcmdZViewItem
yup.. they cost a bomb
vinyas is offline
Old 20-12-2006, 12:54 PM   #10 (permalink)
desertwind's Avatar
8.5 GB DVD-R media costs much higher than it's 4.7 GB variant.
You'll get an unbranded ones for around 80-100. But branded one's costs like hell. It varies from 150-500 per piece.
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 20-12-2006, 12:56 PM   #11 (permalink)
@desertwind : where u gt those Unbranded ones ? .. any idea ? ben looking for cheap DVD- DL
vinyas is offline
Old 20-12-2006, 01:11 PM   #12 (permalink)
desertwind's Avatar
@vinyas: I haven't bought it yet. But was told by a couple of vendors here at hyderabad.
Even this 100 Rs for unbranded is costly for me. I'll go for two branded 4.7 GB discs (unless its a 9gb dvd movie).
Old 20-12-2006, 01:16 PM   #13 (permalink)
@desertwind... if possible get some info on this ... i would be interested
cheer mate
vinyas is offline
Old 20-12-2006, 01:23 PM   #14 (permalink)
"Moserbear 25 DVD Media Spindel Pack
Price : Rs. 850/-"
THIS IS BULL*(
I got
Moserbear 50 DVD Media Spindel Pack
Price : Rs. 1000/-
major edit. sorry, forgot to add proper link
W i d e S c r e e N is offline
Old 20-12-2006, 01:26 PM   #15 (permalink)
Sup' dude, Sup'
Dude, DVD +/- R dual layer itself is priced above Rs. 100 for brands like moser baer, sony etc. There isn't a dual layer dvd that is priced below Rs.50, whether it is branded or non-branded.
ambandla is offline
Old 20-12-2006, 02:21 PM   #16 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Price : Rs. 850/-"
THIS IS BULL*(
I got
Price : Rs. 1000/-
R u talking abt 8.5gb variant or 4.7 gb???
I do not understand Y this thread is here...
wizrulz is offline
Old 20-12-2006, 10:37 PM   #17 (permalink)
harikatt's Avatar
i think here people are little confused..,,,
the rewritable DVD whether dual layer8gb.. or 4.7gb one.. is very high.
but single layered only writable DVD of 4.7 costs 12 or 15 Rs.. unbranded.. since i opted to buy dvd instead of 5-6Rs Cd,, so i know.. but when i asked for and 4.7Gb rewritable DVD then the cost was said to be 150Rs...
so i am talking that... dont be confused of and DVDr ----- DVDrw
harikatt is offline
Old 20-12-2006, 11:06 PM   #18 (permalink)
Single Layer DVD - 4.7 GB
DVD R - Rs. 15-20 (writable only once)
DVD RW - Rs. 100 (rewritable)
Dual Layer DVD - 8.5 GB
DVD R - Rs. 375 (writable only once)
DVD RW - ???? (rewritable) - haven't seen these anywhere
vikz is offline
Old 20-12-2006, 11:17 PM   #19 (permalink)
desertwind's Avatar
You'll get a good quality one for 180-200. But I was offered an unbranded one for Rs. 100 per piece and Rs. 80 if I took 50. But i didn't go for it.
@harikatt: i'm not at all confused.
You won't 8gb dvd (writable once) for less than 50 Rs.
Old 21-12-2006, 12:02 AM   #20 (permalink)
Thanks for the info desertwind. Any idea what brand will be available for Rs.180-200?
The Rs. 375 I paid was for Sony
vikz is offline
Old 21-12-2006, 02:41 AM   #21 (permalink)
gsmsikar's Avatar
this is the correct scene in India , but with slight correction , i.e
DVD R - Rs. 100 to 200 (cheapest) (writable only once)
as this month Digit give 8.5gb DL DVD with the magazine so i thought that 8.5gb dvd are also cheap now a days ..
gsmsikar is offline
Old 21-12-2006, 08:08 AM   #22 (permalink)
@vikz .. DVDRW Moserbaer 2.4x ... selling @ 80 With case
Really good When u want to back temp Files which r big in sizes ..which cannot be put in a peindrive
vinyas is offline
Old 21-12-2006, 08:42 AM   #23 (permalink)
Sup' dude, Sup'
Harikatt, Noone here is confused. Your dealer is confusing you.
A Single layer DVD rewritable is not Rs.150, it's Rs.45 (sony/moser baer).
Dual layer DVD recordable is Rs.150 (sony/moserbaer)
Don't know how much DVD rewritable is.
ambandla is offline
Old 21-12-2006, 07:31 PM   #24 (permalink)
harikatt's Avatar
no no.. i was going to say.. is
dvdr itself means once writable..
dvdrw is rewritable.. feel the difference.. thats all. for who dont know..
thanks. for your replies.. mates.
harikatt is offline
Old 21-12-2006, 10:03 PM   #25 (permalink)
rajaryan_13's Avatar
in Kokata
Sony = Rs 350
Navtech = Rs 190
rajaryan_13 is offline
