Old 19-12-2006, 10:47 AM   #1 (permalink)
Default Upgrading my computer....
Hi Everyone,
I want to upgrade my processor. I would like to know what should i go go for. Should i go for Intel Core 2 Duo or AMD 64. I have an Geforce FX 5200 256MB AGP graphics card. I want to keep that! So please tell me some motherboard and processor combinations that is good and the price as well! Thanx.
hell_storm2004 is offline
Old 19-12-2006, 10:53 AM   #2 (permalink)
Default Re: Upgrading my computer....
Originally Posted by hell_storm2004
Hi Everyone,
If you want for gaming you can always go for AMD in most of game reviewing sites i have seen an upper hand of AMD
thetechsavy is offline
Old 19-12-2006, 10:55 AM   #3 (permalink)
18 Till I Die............
Moved to Hardware Troubleshooting. Plz post hardware queries here
http://www.bash.org/?258908
mehulved is offline
Old 19-12-2006, 11:04 AM   #4 (permalink)
caleb's Avatar
The newer processors like Core 2 Duo require new mobos and these days the good motherboards that support Core 2 Duo do not have AGP slots as almost all mobo manufaturers have moved on to PCI-e if you are upgrading to a new processors like Core 2 Duo (I do not know much about AMD) it is better that you sell your gfx5200 and buy a new one.
Also tell us of your budget...usually when someone says that they'd like to keep their existing AGP card expecially when it is a low end 5200 it most likely means that you are on a tight budget...so let us know what you can spend and you will get a more specific answer.
caleb is offline
Old 19-12-2006, 11:06 AM   #5 (permalink)
budget is not a problem.... if i sell my old set i would get sumthin back..... so make it Rs 10000 to Rs. 13000.....
Old 19-12-2006, 02:47 PM   #6 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
10 to 13 k for mobo+procyy?
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
