Old 18-12-2006, 07:11 PM   #1 (permalink)
Default SMPS problem
hey ppl,
i'm having problem with my spms...there was i loud noise when i switched on my PC and after that there was a burning smell coming out of my SMPS.....
so i'm guessing my SMPS went POOF!!
it was a 300w microtek SMPS, can anyone recommend me a good quality SMPS...i generally leave my PC on for days at an end
it has just one fan apart from the SMPS one...
also, i have 3 optical drives and a 6600 graphics card which requires a power cable, my system spces are given below:
P4 2.6 Ghz
intel D865GBF motherboard
1 GB ram
Geforce 6600 graphics card
3 optical drives
1 floppy drive
1 seagate 160GB SATA hard-drive
setharsh is offline
Old 18-12-2006, 07:14 PM   #2 (permalink)
samrulez's Avatar
Default Re: SMPS problem
VIP/Powersafe 300watts.....or 400watts...
Sam :D Rulez :lol:
samrulez is offline
Old 18-12-2006, 07:41 PM   #3 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Antec 650 W.......A friend of mine has it .....it simply rules
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 18-12-2006, 09:43 PM   #4 (permalink)
shantanu's Avatar
JUST GO FOR COOLING MASTER 550 watts coz it will come in a handy budget of rs. 1900/- and everyone knows cooling master is another good brand as antec
but i too use antec 650 FAN less and its great but really very very expensive if you can spend 8000/- bucks then go for it ,, as it simply rules..
shantanu is offline
Old 19-12-2006, 12:47 AM   #5 (permalink)
I forgot to mention its COSTLY damn costly
Sony Vaio CW26FG
Old 19-12-2006, 12:48 AM   #6 (permalink)
shantanu's Avatar
ya thats i meant to say
shantanu is offline
Old 19-12-2006, 12:49 AM   #7 (permalink)
8000 bucks will get ya a CORE2DUo or an ANTEC SMPS
Sony Vaio CW26FG
Old 19-12-2006, 01:12 AM   #8 (permalink)
shantanu's Avatar
But Quality Sees No Pricing
shantanu is offline
Old 19-12-2006, 08:23 AM   #9 (permalink)
gooby pls
Third Eye's Avatar
@setharsh: Mention the budget....
If money is not a problem then you can go for Antec 400Watt PSU otherwise go for local iball type psu....
Third Eye is online now
Old 21-12-2006, 09:57 PM   #10 (permalink)
thnx for the help guyz....
my budget is around 2000K
__________
BTW....i live in delhi....so plz suggest brands that are easily available here..
setharsh is offline
Old 22-12-2006, 10:39 AM   #11 (permalink)
gooby pls
Third Eye's Avatar
__________
Then you can go to 'Nehru Place' to purchase Antec 400PSU...
I don't know the exact price of Antec 400PSU but it was around 2000-2100 last year....
Old 22-12-2006, 12:45 PM   #12 (permalink)
GaurishSharma.com
gary4gar's Avatar
any smps of 400w below 1k???
gary4gar is offline
Old 22-12-2006, 01:01 PM   #13 (permalink)
rajaryan_13's Avatar
IN kolkata Antec 350W PSU costs 4000+
rajaryan_13 is offline
Old 22-12-2006, 01:47 PM   #14 (permalink)
gooby pls
Third Eye's Avatar
iBall
Old 22-12-2006, 02:27 PM   #15 (permalink)
shantanu's Avatar
IS Iballl good enough
shantanu is offline
Old 22-12-2006, 02:32 PM   #16 (permalink)
I ball would be better than going in for any local brand.....but no where near Antec
Sony Vaio CW26FG
Old 22-12-2006, 03:02 PM   #17 (permalink)
gooby pls
Third Eye's Avatar
iBall is a decent SMPS....i am using it.....
Old 23-12-2006, 11:12 AM   #18 (permalink)
GaurishSharma.com
gary4gar's Avatar
wanted to check b'cos as i am not a gammer so don't need that much power
any one tell its specs like how many volts on the rail
gary4gar is offline
Old 23-12-2006, 04:01 PM   #19 (permalink)
Currently using i-Ball 400W (priced 450/-), its a crap I believe, coz needed to unplug CD-RW, FDD to run the mchine
Old 23-12-2006, 06:09 PM   #20 (permalink)
Man 400 W smps n u got to unplug both CD-RW n FDD to get the machine started.......
I could run everything when i had a 300W smps in my old config...
go get it changed man
Sony Vaio CW26FG
Old 30-12-2006, 08:13 PM   #21 (permalink)
DigitalImmigrant's Avatar
PowerSafe 400 watts @ Rs 1600 .
Powersafe 500 watts (dont know )
Cooler Master Extreme Power 350 watts @ 2100.
DigitalImmigrant is offline
