Old 18-12-2006, 12:48 PM   #1 (permalink)
Working in an IT company
Default Divide unallocated disk space to existing partitions
I hav 2 partitions: drive C(physical drive) & D(logical drive), each having a disk space of 20 GB. I will b installing a new hard disk of 80 GB soon. My aim is to divide & distribute that 80 GB space equally to my exisiting partitions(C & D) so that the new total space of the 2 drives becomes 60 GB each. I dont want to create any extra drive E or whatever. How do i do that ? I know that i will hav to do this from Disk Management in windows Xp but i dont know the exact procedure. Can any1 help me with this ?
varunb is offline
Old 18-12-2006, 01:47 PM   #2 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Default Re: Divide unallocated disk space to existing partitions
I am not very sure but i think this cannot be done. Using space from two different Hard disks n sharing it on one partition pretty doubtfull
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 18-12-2006, 05:02 PM   #3 (permalink)
Check out Acronis Disk Director Suite it may be able to do what you want...
https://ssl.saversoftware.co.uk/details-647.htm
The suite includes the Acronis Partition Expert product which allows you to automatically or manually merge, split, resize, copy, and move partitions without losing data. It also lets you reorganize the hard disk drive structure, optimize disk space usage and much more.
suman2005 is offline
Old 18-12-2006, 05:08 PM   #4 (permalink)
shantanu's Avatar
yeah you can install magic partition and do this and surely it can be dont and is very easy in windows vista bt you must be using xp so install
partition magic
shantanu is offline
