Old 18-12-2006, 02:51 AM   #1 (permalink)
niku_19jan's Avatar
Default mobo needed
hey i hav pentium iv 1.8 ghz n i hav mercury mobo 845glva. i want to change the mobo tat have pci express n onborad radieon graphics. it shld also hav suport of ddr2 ram, so can ny body help me????????
niku_19jan is offline
Old 18-12-2006, 02:55 AM   #2 (permalink)
shantanu's Avatar
Default Re: mobo needed
you can go to:
http://in.asus.com/products3.aspx?l1...20Xpress%20200
this has pcie and ddr2 support
shantanu is offline
Old 18-12-2006, 01:36 PM   #3 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Thats a real good motherboard.........Niku go in fot this motherboard
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 18-12-2006, 03:24 PM   #4 (permalink)
shantanu's Avatar
Sorry to say i was a little wrong a good mobo but not DDR2 support
shantanu is offline
Old 18-12-2006, 04:00 PM   #5 (permalink)
The best feature of that motherboard is its Onboard ATI X200(dedicated X300) with 256 mb(by sharing 64 mb from RAM)..........
Sony Vaio CW26FG
Old 18-12-2006, 04:55 PM   #6 (permalink)
shantanu's Avatar
and thats a pcie card onboard with Sm2 controllers and supports VISTA
shantanu is offline
Old 18-12-2006, 05:50 PM   #7 (permalink)
with vista round the corner.......we really need vista compatible stuffs
Sony Vaio CW26FG
Old 18-12-2006, 07:47 PM   #8 (permalink)
niku_19jan's Avatar
man thn can u suggest me which wil support ddr2 as well.....
Old 18-12-2006, 07:55 PM   #9 (permalink)
I could not find any mobo having ati x200 ,ddr2 , support for 478 P4
Sony Vaio CW26FG
Old 18-12-2006, 08:37 PM   #10 (permalink)
niku_19jan's Avatar
ok bro no prob wil settle with tat previous one.....
Old 18-12-2006, 09:32 PM   #11 (permalink)
shantanu's Avatar
yeah that board is really good try and go for that RECOMMENDED
shantanu is offline
Old 19-12-2006, 04:32 PM   #12 (permalink)
niku_19jan's Avatar
ok wil purchase tat. thnks 4 ur suggestions.
Old 22-12-2006, 05:26 PM   #13 (permalink)
shyamno's Avatar
Hve u got that mobo..i.e P4RD1-MX..please tell me from where you got it..Please reply soon...
shyamno is offline
Old 22-12-2006, 09:32 PM   #14 (permalink)
I called Asus and its not available
Kshitiz_Planetgaming is offline
Old 23-12-2006, 02:32 PM   #15 (permalink)
niku_19jan's Avatar
shyamno i had replied u. check ur msg.
