18-12-2006, 01:21 AM
Will have to buy a 5.1 speaker system
Well guys I need to purchase a decent looking  4.1 or 5.1 speaker system for my girl frnd's comp which uses a intel 865 GBF mobo.Well if FM came with the speakers that'll be very good but its not a necessity.My budget is about Rs.1500-Rs.3500/-
C2D E6600,Asus P5N32 e SLI,1GB 667mhz,Samsung 940BW,Zeb 8600GT,Seagate 250GB sata II,16x Sony(OEM) dvd RW,Zeb Anitibiotic & Platinum 500W,Microsoft desktop pro 700,bluetooth,Logitech MX Revolution
18-12-2006, 01:29 AM
Re: Will have to buy a 5.1 speaker system
go for creative SBS 5.1 ..
or F n D 640L rs.2800/- very decent and nice looking
18-12-2006, 02:01 AM
Rebooting
yeah 3.5k means u can squize a 5.1 Creative.. but if Style is a major concern then u may think of the Intex model available here at Kolkata at the price of 2.9k... This model has a cooool Wooden look.. sound isnt that bad either.... how ever not good as Creative... but the major con is the Post sells service of Intex...
rebooting
ChotoCheeta.com
18-12-2006, 03:16 AM
BUT dont you think that intex is not good at sound its really chuck i feel ..had four 5.1 again but had a same problem ok ticking sound s so its not worthed.. while its only my advice dont take it otherwise
18-12-2006, 04:45 AM
creative SBS 5.1 560/580 seemed pretty nice to me and the price is also appealing.....well she has a small square room and needs the setup for watching DVD movies mostly so I guess this system shud be good enough.
Well, "F n D 640L" wats that?
18-12-2006, 07:21 AM
Stick to Creative or Artis. Good ones.
Kiran Kumar R
18-12-2006, 10:38 AM
Rebooting
well as per looks go Intex Wooden Looks was better in that 3.5k range.. but i have pointed na.. Intex is no where near to Creative while in Quality and Intex has a issue with post sales service...
rebooting
ChotoCheeta.com
18-12-2006, 03:47 PM
F n D Are just like packing inspire 5.1 with more 200 watt rms output power great one buddy used that with remote and FM
18-12-2006, 05:21 PM
gooby pls
Well,Creative Inspire 5200 5.1 is good enough,don't know the current price but i bought it in Rs 4200 last year...May be the price will be reduced now....
18-12-2006, 05:41 PM
TechTin.com
I will also suggest creative inspire SBS 5.1..it will come for 2600 in delhi..rest money u can use 2 buy a sound card.I will suggest u creative blaster which will cm for 1200/- in delhi.
Never choose 4.1,it wont give a better surround effect.
18-12-2006, 10:46 PM
I went to the Artis website and was chkin out 5.1 spkrs........can anybody tell wat is the price range of these spkrs?
19-12-2006, 07:49 AM
Price varies a lot depending upon the PMPO watts. It starts from few thousands to as high as Rs.17000/-
Kiran Kumar R
19-12-2006, 08:03 AM
You can also go for Altec Lansing. The model 151i and 251i should fall within your budget. The 251i is a good set and IMO better than the Creative models in that range.
