C2d some models are better then x2
but x2 3800 beats C2d in many tests so you cant say that C2d is better then X2.. try the benchmarks ans competitive results at :
www.amd.com
and if you have a c2d with you or near by a friend try running everest or sissoftware sandra and compare the results with amd different models.. you will see that basic C2d is beaten by Amd x2
yA DUDE I TESTED IT in everest ultimate edition and found the results so thet are also not incorrect...
