Old 16-12-2006, 07:41 PM   #1 (permalink)
Exclamation AGP recommendation
Hi.. i need to buy an agp card with foll features
1. 256 bit
2. TV out support (i wanna definitely be able to watch on ma TV)
3. cost less than 5K
for my A7N266-VM board
Specs of the board here : http://www.superwarehouse.com/Asus_A...N_AA/ps/124985
Any recommendations??
gr8usr is offline
Old 16-12-2006, 07:44 PM   #2 (permalink)
shantanu's Avatar
Default Re: AGP recommendation
you have Nvidia nforce chipset running amd i think..
256 bit you should take a look
http://www.nvidia.com/page/geforce_6800.html
shantanu is offline
Old 16-12-2006, 07:46 PM   #3 (permalink)
Thanks for the quick reply but wats the price?? n will it work on ma comp for sure??
gr8usr is offline
Old 16-12-2006, 07:54 PM   #4 (permalink)
shantanu's Avatar
ya my friend is using the same board with amd athlon xp 2000+
and having a 6800Ultra working fine
6800GS about 5.2k
6800le about 3.5k
for more details check out:
Latest Processor Prices
shantanu is offline
Old 16-12-2006, 08:13 PM   #5 (permalink)
according to my mobo manual it says i can only install a agp4x card...
and its interface looks like
||||'''||||'''||||'''|,, <-hope u understand wat m tryin to say..
now most o the cards mentioned the 6800 etc have the port looking very different...
someone please help..
gr8usr is offline
Old 16-12-2006, 11:03 PM   #6 (permalink)
shantanu's Avatar
look bro the cards minimum requinment is agp 2x and you have 4x trust me it ll work just had to have 256 mb ram and 2x slot you can run a 4x card on it
shantanu is offline
