Old 16-12-2006, 06:45 PM   #1 (permalink)
Default Help needed
Hi
I need a comp for my office. I have decided to base it on pentium D processor.
Please help me in deciding the components. It should have onboard graphics, sound, LAN. I want to keep the cost to around 20k. It should be upgradeable in the future. Please give me the details of each component viz. model number, price and from where should I purchase it in Mumbai.
troubleshooter is offline
Old 16-12-2006, 07:01 PM   #2 (permalink)
Tech Geek's Avatar
Default Re: Help needed
http://www.techtree.com/techtree/jsp...280&cat_id=556
Tech Geek is offline
Old 16-12-2006, 07:13 PM   #3 (permalink)
Go for Intel Board if you want onboard graphic card
Mother Board : INTEL DG965RY (Intel® Graphics Media Accelerator X3000 )- Rs6600
RAM : KINGSTON DDR2 256 MB - Rs1700
Monitor : SAMSUNG 15" 591S - Rs3700
CD Writer : 52x SAMSUNG - Rs900
Keyboard & Mouse : Logitech - around Rs750
Sound Card : Onboard
Lan Card : Onboard
HDD : 80 GB SATA (SGT\SAMSUNG) - Rs2100
Speaker : Around Rs 450
abhipal is offline
Old 16-12-2006, 07:22 PM   #4 (permalink)
shantanu's Avatar
go for AMD
cpu :Amd athlon 64 3000+
mobo:asus k8v-vm
ram :512 ddr 400mhz
dvd-rw:sony
monitor:15" samsung/LG
PSU:400 watt local vendor with cabinet
HDD:80 gb sata samsung
normal keyboard mouse
this config will be around 16000/- add a UPS 2000 more
this is a upgradable pc and you can install more ram and gfx card anytime
i think will work.. and also wait for others to post here look what they say
shantanu is offline
Old 16-12-2006, 07:24 PM   #5 (permalink)
Tech Geek's Avatar
Monitor-->PHILIPS 17" 107 Rs4300
Combo Drive-->LG Rs1100
Speakers-->CREATIVE SBS 370 Rs1100
Graphic Card-->128 MB NVIDIA GF FX 5200 Rs1900
Hard Disk-->80 GB (7200 RPM) Rs1950
Motherboard-->INTEL D965RY Rs6600
Processor-->E6300 (2MB L2 cache 1.87Ghz 1066MHz FSB 65nm) Rs8300
Total-->17,400Rs
Some more things needed.
Old 16-12-2006, 07:36 PM   #6 (permalink)
Dont go for Philips monitor go for Samsang monitor. Its display is good.
For Optical drive if CD ROM/Writer go for Samsang If DVD Writer go for Sony.
You won't need Graphic card as INTEL D965RY have Intel® Graphics Media Accelerator X3000 which can even run VISTA.
abhipal is offline
Old 16-12-2006, 09:16 PM   #7 (permalink)
Total-->17,400Rs
dude total comes out to be Rs25250.
A weird thing about humans is we work till we\'re sick to get a fortune, then pay a fortune to get well again.
The road to success is always under construction.
harmik is offline
Old 16-12-2006, 09:28 PM   #8 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Just see my signature........My config is something that can help you in deciding.
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 17-12-2006, 12:14 PM   #9 (permalink)
Tech Geek's Avatar
5K extra wouldn't matter when you are getting a good PC.
He does not need to upgrade for abt. 2-3 yrs
Old 17-12-2006, 12:17 PM   #10 (permalink)
Its his personal choice whether he wants to spend 5K more or not........He may be on shoe string budget........
Sony Vaio CW26FG
Old 17-12-2006, 12:20 PM   #11 (permalink)
Tech Geek's Avatar
Ya, even i thought of that. But still he does not have to replace that for 2-3 yrs.
Old 17-12-2006, 05:54 PM   #12 (permalink)
5k extra dont matter, but the config should be such that i should not be compelled to upgrade for say 2 - 3 yrs
Old 17-12-2006, 05:56 PM   #13 (permalink)
So ur budget is now 25K.....In total
Sony Vaio CW26FG
Old 17-12-2006, 06:02 PM   #14 (permalink)
Lan Card : Onboard
Following changes required
speaker not required, Ram 512MB DDR2 , HDD either 120GB/160GB Seagate/Hitachi, Combo drive from Sony instead of a plain cd writer. what would the final cost come to and can u give me the shop name & contact number from where you inquired about the same.
In the future i may be using my system to use Corel Draw Auto CAD
Old 17-12-2006, 06:21 PM   #15 (permalink)
Which Pentium D are u planning to buy? Which model number?
Sony Vaio CW26FG
Old 17-12-2006, 08:17 PM   #16 (permalink)
shantanu's Avatar
GO FOR A Ati chipsET board like D102 will give you more performance
shantanu is offline
Old 17-12-2006, 08:44 PM   #17 (permalink)
Thats really true..............
Sony Vaio CW26FG
Old 17-12-2006, 08:50 PM   #18 (permalink)
shantanu's Avatar
at least go for 512 mb ram as 256 makes no pint at this time
shantanu is offline
Old 18-12-2006, 04:21 PM   #19 (permalink)
Thats 100% true......512 mb is a bare minimum now a days.
Sony Vaio CW26FG
Old 18-12-2006, 05:01 PM   #20 (permalink)
shantanu's Avatar
and go for A SONY OR HP DVD RW
shantanu is offline
