Re: connecting pc wid laptop?
Almost all laptop have a lan port, so you can use it for sharing the internet connection or transferring files. lan is the cheapest solution, you just need a cross over cable. If transferring files is your major concern, you should consider pen-drives, external hdd's and bridged usb cables.
Yes, hdd's are the slowest part in your computer. the 20GB IDE would be even slower. And the fact that it a used one, made to work on the new PC would affect the system performance adversely. So, you should go in for a new sata hdd, they are as cheap as they can get. You would be surprised about the performance boost.
