Old 16-12-2006, 12:16 PM   #1 (permalink)
sujeet2555's Avatar
Default bsod:on hardwre upgrade
i had a via 845gl board,512 mb ddr,80 gb hd,nvidia mx 4000 with windows xp sp2 pro.i recently bought a new motherboard that is asrock p4i845gv.on installation the system gives the error STOP 0X0000007B(0XF8B18640,0XC0000034,0X00000000,0X0000 0000) and says something about hard disk controller,virus,run chkdsk...please anyone
s.k.
sujeet2555 is offline
Old 16-12-2006, 01:23 PM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: bsod:on hardwre upgrade
run memtest on ur ram modules....
You may receive a "Stop 0x0000007B" error message if your computer is infected with a boot-sector virus.
go here ...read it ..wil help u to solve problem
http://support.microsoft.com/kb/324103
Give ur feedback
wizrulz is offline
Old 16-12-2006, 04:57 PM   #3 (permalink)
shantanu's Avatar
yeah surely affected by a boot sector virus clean up your whole HDD and MBR .
means do partioning again with DM if you have
seagate:
http://www.seagate.com/support/disc/...s/discwiz.html
go for the starter edition and select cd image and download (burn it to a cd and then boot from it
if you want a diagnostic tool for removing virus only
seagate:
http://www.seagate.com/support/seatools/
cd image
birun and use
samsung DM:al in one
http://www.samsung.com/Products/Hard...ties/index.htm
shantanu is offline
Old 16-12-2006, 05:25 PM   #4 (permalink)
Distinguished Member
anandk's Avatar
download the primer ... click The "Blue Screen Of Death".
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
