Though my modem is different, here is the screen shot
Originally Posted by keep_it_rl
Item Downstream Upstream Unit
SNR Margin 34.0db 14.0db dB
Line Attenuation 28.5db 12.5db dB
Loss of Signal 0 0
CRC Errors 8 0
Data Rate 2048 Kbps 512 Kbps kbps
Latency Fast Fast
Dude these are the stats are they normal
As far as i know.....
It seems
your upstream & downstream SNR is problematic.
though attenuations are somehow ok.
Your modem UTStar 300R,so you can't get this field value like MT882.
and how you get 512kbps/2048kbps ??????
This is highly questionable...Earlier you mention you have 900ul plan....
so your value must be 256kbps/2048kbps.
Possible cause....BSNL's local router can't synchronize your connection.
(correct me if i am wrong)
Check your line with BSNL's guys.
