Old 11-12-2006, 09:53 PM   #1 (permalink)
Cool Pentium 4 dual core and Core 2 duo
Please explain the difference between pentium 4 dual core and pentium 4 core2 duo processors?Which one is better and is there any AMD equivalent of core2duo?
gunda_26 is offline
Old 11-12-2006, 10:24 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Pentium 4 dual core and Core 2 duo
Well both P4 Dual Core and Core 2 Duo is dual core processor but Core 2 Duo is faster on those 2..
yup.. AM2 range products are suppose to compete with Core 2 Duo... but at the moment Core 2 Duo is simply better and faster than any available AMD processor...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 13-12-2006, 04:32 PM   #3 (permalink)
Pragadheesh's Avatar
Post Re: Pentium 4 dual core and Core 2 duo
but wats d actual difference between core 2 duo n dual core wen both employs 2 processors?? i want to know in detail...
Pragadheesh is offline
Old 13-12-2006, 04:51 PM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
The core 2 duo's range mostly has a double capacity L2 cache than P-Ds and also, they have a better power consumption (lesser) design than P-Ds. Also, it isnt based on Netburst. Plus its 65nm I guess...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 13-12-2006, 06:15 PM   #5 (permalink)
The High 5 Flyer
sam9s's Avatar
First of all, Pentium 4 and Core 2 Duo are two different processor all together, there is no P-4 C2D. The chip for C2D is code named Conroe.
Pentium D again is in no comparision with C2D, P-Dd were phusdo
dual cores where in C2D have actual 2 cores residing on different dies.
CO this link for a detail review on C2Ds
http://www.techreport.com/reviews/20...2/index.x?pg=1
sam9s is offline
Old 15-12-2006, 12:53 AM   #6 (permalink)
ayush_chh's Avatar
now what's phusdo dual cores....?
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 15-12-2006, 03:54 PM   #7 (permalink)
assasin's Avatar
I think he meant pseudo dual cores
assasin is offline
Old 15-12-2006, 04:32 PM   #8 (permalink)
Loading . . . please d'nt
CINTEL ENTRINO's Avatar
pseudo = false .
CINTEL ENTRINO is offline
Old 22-07-2009, 08:28 AM   #9 (permalink)
in the era of core i 7 and dual quad core still many of people searching for difference between dual core and core 2 duo.
Difference Between Intel Core 2 Duo vs Dual Core vs Pentium D read it here
http://www.ialwayscapital.com/2009/0...-2-duo-vs.html
www.ialwayscapital.com [....coz an "I" always CAPITAL ]
ialwayscapital is offline
Old 22-07-2009, 09:44 AM   #10 (permalink)
BSD init pwns System V
hellknight's Avatar
OMG.. this might be the record in bumping an old thread
My blog :- www.openenclave.wordpress.com
hellknight is offline
Old 25-07-2009, 10:20 AM   #11 (permalink)
laborare est orare
Cilus's Avatar
Intel Pentium D or Dual core is not a true dual core processor. Here two separate P4 processors with hyperthraeding Support are put into a single package. They don't have any intercommunication channel inside the processor die, they share data through the Motherboard FSB. Their Power consumption is high and performance is on the lower side. They are the worst performing Dual Core processor (Even worse than Older Athlon X2). Their multitasking handling is poor, since they don't have interprocessor communication. They are often termed as Twin Core Processor.
Core2Duo are a new breed of true dual core processors. Here two processor cores are implemented in a single die, not in a separate package. They have interprocessor communication channel and they communicate with the Motherboard FSB as a single entity, not to separate processors. Intel also implemented centrino technology of their Mobile processors in Core2Duo. Hence they are highly power efficient. Their FSB is also higher than Pentium D (Minimum C2D FSB is 1066Mhz, for Pentium D:800 Mhz). So even low clock speed C2Ds (Like 1.8 Ghz) are far more better performaer than Pentium D clocked over 2.5 Ghz.
A Core2Quad is a Twin Dual COre Processor, 2 separate C2D processors are placed in a single package. But Core I7 is similarly is a true Quad Core (4 processor cores are implemented in a single die).
Cilus is offline
Old 25-07-2009, 10:28 AM   #12 (permalink)
TheHumanBot's Avatar
3 years old thread BUMP
TheHumanBot is offline
