Old 10-12-2006, 01:32 PM   #1 (permalink)
Default Samsung Hdd problem please help
I am having Samsung (SV4002H) 40 GB HDD it is 4year old
the problem is that even after fdisk & formatting computer is not able to boot from it
when i boot from bootable cd then prompt can gon on c: & d:
and drives are available file get copied & pasted but why is not booting
i tried formatting for dos booting then also same problem
i tried WinXP setup setup gets installed but when setup is going restart and setup does not start futher
sorry for bad english but please try to understand my problem
help me
would this problem be solved with zero fill if yes please provide me link to image file of bootable zero-fill cd
i also tried the Hutil.exe from samsung.com for low level formatting but this hutil is not detecting my HDD
i own A Intel D102GGC motherborad & 3.2 ghz processor (641)
one thing to note that hDD works fine in XP means i have another 80 SATA which i use as my primary hdd
i want to sell my this 40 gb and take another one of 80GB SATA
please help
chandansomani is offline
Old 17-12-2006, 03:32 AM   #2 (permalink)
shantanu's Avatar
Default Re: Samsung Hdd problem please help
Help Him Guys No One Here To Help Common
shantanu is offline
Old 17-12-2006, 04:18 AM   #3 (permalink)
@chandansomani do low level partition using win98 bootable cd
Dhiraj Thakur
thakur.dheeraj(@)gmail.com
Desi-Tek.com is offline
Old 18-12-2006, 03:44 AM   #4 (permalink)
shantanu's Avatar
Lightbulb Re: Samsung Hdd problem please help
YES , A LOW LEVEL PARTIONING WILL DO I THINK
shantanu is offline
Old 18-12-2006, 09:04 AM   #5 (permalink)
What is a low level partitioning ? Is it different from a regular fdisk partitioning ?
suman2005 is offline
Old 18-12-2006, 09:09 AM   #6 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
refer this
How to do a low level format??
wizrulz is offline
Old 18-12-2006, 09:18 AM   #7 (permalink)
Originally Posted by wizrulz
The link you gave talks about low level formatting... I know about low level formatting ... I did not know about low level partitioning which has been mentioned here. I suppose it was just a typo
