Old 10-12-2006, 06:31 AM   #1 (permalink)
jatt's Avatar
Exclamation difference in between two
is there any difference in vedio capture card and firewire if i need one only
which is right and better
jatt is offline
Old 10-12-2006, 08:13 AM   #2 (permalink)
Default Re: difference in between two
i think you are mistaking a tv tuner card with a dv card used for recording tapes off a handycam.. as they usually need a firewire port
correct me if am wrong
da_tcpip is offline
Old 10-12-2006, 03:57 PM   #3 (permalink)
The High 5 Flyer
sam9s's Avatar
Any card that captures video can be termed as video capture card. A TV tuner card can also capture video. But we usually use the term "Capture card" for dedicated card specifically designed to capture. A fire wire card is also a capture care which uses an IEEE1394 Firewire PCI card for a high data rate (around 400 Mbps). While new USB 2.0 technology also raises USB speed to 480 Mbps, the recently finished specification for IEEE 1394b has a maximum speed of 800 Mbps. Refer my this thread for some more insite.
Camcorder USB to Firewire to Video Capture/Editing: Possible?
sam9s is offline
Old 10-12-2006, 10:17 PM   #4 (permalink)
Thumbs down Re: difference in between two
he is RIGHTTTTTTT
VIDEO CAPTURE CARD IS USED TO CAPTURE VIDEOS AND ALSO NOW A DAYS IN MEDIA CENTERS,,
BUT FIREWIRE IS DIFFERENT
Genius_mod is offline
