Old 10-12-2006, 12:17 AM   #1 (permalink)
Default how to play a protected VCD on PC?
well
i have got a set of 3 original VCDs of an old theater play.( i purchased it)
But the problem is that, i don't have a dvd/vcd player for my TV and the VCDs don't even get recognised in my Sony DVD writer...plz help...
I can't get to the dealer ( in pune) of VCDs...also the cover of VCDs doesn't say nething about PC incompatibility...
BTW it does works in my friend's VCD player and doesn't in his PC too....
ashnik is offline
Old 10-12-2006, 12:27 AM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: how to play a protected VCD on PC?
IF it is not getting detected then i do feel anone canhelp u ...untill it gets detected ...
wizrulz is offline
