Old 09-12-2006, 05:47 PM   #1 (permalink)
Question Hard disk to buy ?
Can anyone suggest a good hard disk to buy ?
I need minimum of 300GB space and please quote the price too
sbhas2k is offline
Old 10-12-2006, 07:11 AM   #2 (permalink)
"Technologic"
Apollo's Avatar
Default Re: Hard disk to buy ?
Last I checked, a Seagate 7200 rpm 320GB hard drive was priced just over Rs.5000/-
One great use of words is to hide our thoughts.
Apollo is offline
Old 10-12-2006, 09:59 AM   #3 (permalink)
ymhatre's Avatar
hmm going for 300 + space...
I dont know which brand you go after...but last time i bought my friend Western Digital 250GB HDD for 4050 RS 16mb cache
As i said brand wont be a problem...
just make sure you go for 16 mb cahce....
that helps like hell in transferring file
and i heard Western Digital 300 Gb was for 4700 RS 16 mb cache
DusT = ME
Rate me if was clear to you
ymhatre is offline
Old 10-12-2006, 11:55 AM   #4 (permalink)
Kiran.dks's Avatar
Brand matters a lot, especially when it comes to reliability. Go for Seagate brand.
Kiran Kumar R
Kiran.dks is offline
Old 10-12-2006, 12:40 PM   #5 (permalink)
Tech Geek's Avatar
SGT Harddisks
250 GB (7200 RPM) Rs3600
300 GB (7200 RPM) Rs4400
320 GB (7200 RPM) Rs4600
Tech Geek is offline
