Old 09-12-2006, 04:16 PM   #1 (permalink)
Team Digit
r4gs's Avatar
Default Power supply for 7900GS
Hi,
My uncle offered to get me a 7900GS when he comes back (in abt a week) from Singapore.
Problem is that I have a 300W smps (19A 12V rail). The PC is an HP one so I know it is reliable but is the power enough for such a card?
The PC config is
P4- 630 (3 GHz, 800MHz FSB)
2x512mb GB DDR II 400Mhz RAM
1 cd rom drive (which can be disabled if necessary)
1 DVD RW drive
2 USB printers (Laser and inkjet)
Also, if the power is not enough, will at least an X1600 or GF-7600GT run?
Thanks
r4gs is offline
Old 09-12-2006, 05:44 PM   #2 (permalink)
sam_1710's Avatar
Default Re: Power supply for 7900GS
i'm runnin Pentium D 2.8 GHz proc, 1GB DDR2 533 MHz, 1 LG DVD RW, wid a Zebronics 7600 GT on a 300W smps ..... havin no power problems at all !! dunno how a 7900 will work ..
sam_1710 is offline
Old 10-12-2006, 12:46 PM   #3 (permalink)
No pain....No gain
john_the_ultimate's Avatar
For the 7600gt the power supplied by the PCI-E slot (75W) is sufficient but for the 7900gs u need more than 75W so it requires an extra power connector. I would suggest that at minimum u get an ANTEC 350-400W.
john_the_ultimate is offline
Old 10-12-2006, 01:19 PM   #4 (permalink)
deathvirus_me's Avatar
As u have a Pentium4 630 CPU ,i seriously advice u to change ur PSU .. a min. of 350W with 22A across 12V (preferably dual) ... i can suggest an Antec PSU , check out the new Basiq lineup ...
deathvirus_me is offline
Old 10-12-2006, 04:43 PM   #5 (permalink)
Team Digit
r4gs's Avatar
OK, so the 7600GT it is.
I can't upgrade my power as my comp was given by the company, but i'll try and get more RAM.
Thanks a lot guys.
r4gs is offline
Old 10-12-2006, 04:46 PM   #6 (permalink)
samrulez's Avatar
your SMPS will blow up dood....if it can't supply the required power to the system...
Sam :D Rulez :lol:
samrulez is offline
Old 11-12-2006, 12:23 AM   #7 (permalink)
No pain....No gain
Sam is right,.......300W is not enough, better get a ANTEC 350W, also check the new lineup as deathvirus_me has suggested.
