Old 09-12-2006, 01:36 PM   #1 (permalink)
Back to l33ching :)
gauravakaasid's Avatar
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
Question Laptop HDD not found! HELP!!
i just got home my friend's nu lappy, its a Presario C300. it came with FreeDOS. but i wanna format and repartition the drive. am using a bootable Win XP pro SP2 cd to boot from, but it says that it couldnt detect any hard drive to install windows to. how is that possible?
PS- there was a HDD diaganostic in the BIOS menu, i ran that too. all tests were successful. then where have i gone wrong?
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain
gauravakaasid is offline
Old 09-12-2006, 02:30 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Laptop HDD not found! HELP!!
u r on a SATA HDD... may be XP doesnt include its driver support...
at the time while u boot with XP installation disk press F6 ro load external SATA driver/controler...
download from here...
Intel SATA AHCI Controller Driver
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 09-12-2006, 04:18 PM   #3 (permalink)
Back to l33ching :)
@saurav_cheeta... but i dont have a floppy drive and neither does the lappy. how do i fix this?help me out
Old 09-12-2006, 04:59 PM   #4 (permalink)
Rebooting
hmm... well wait for others to suggest what to do while no Floppy... one quick suggestion what i have is use nLine to include the driver in to ur XP Insyallation CD...
http://www.nliteos.com
Here is a guide... how to include drivers...
http://www.nliteos.com/guide/part1.html
just use WinRAR to exctract the driver.exe what u have downloaded... then use nLite to include the driver and follow the bellow guide to make a Bootable CD of XP...
http://www.helpwithwindows.com/Windo...p2-bootcd.html (just follow the burning part...)
here is the Boot.ima file... http://www.tacktech.com/pub/microsof.../bootfiles.zip
P.S. One more way... Though its for advance users... still u can also try looking in this post http://www.msfn.org/board/index.php?showtopic=13173
rebooting
ChotoCheeta.com
