Old 09-12-2006, 02:09 AM   #1 (permalink)
pra_2006's Avatar
Question LCD Monitors Help URGENT
hi friends i am going a buy a new LCD monitor for my PC so i want to know is there any LCD Monitor available which also supports cable so if i want to see any channel i can see it or when i want to use my PC i can use it pls reply me fast with model number and price and it should be not too much costly
pra_2006 is online now
Old 09-12-2006, 02:50 AM   #2 (permalink)
Thumbs up Re: LCD Monitors Help URGENT
you are talking about LCD TFT
SO IF YOU WANT TO BUY A LCD MONITOR THEN Go for Samsung :
model no.LCD 740n 17" as its very cost effective around 8500/-
more: http://www.samsung.com/au/products/monitors/index.asp
it supports TV TUNERS and ONE MORE THING THAT IF YOU ARE TRYING TO BUY MONITOR (LCD) MEANS NOT LCD TFT THEN GO FOR HCL
www.hclinfosystems.com
Genius_mod is offline
Old 09-12-2006, 03:36 AM   #3 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Default Re: LCD Monitors Help URGENT
watever u buy keep in mind that its response time should be low........
Some come with 14ms but some with 4ms.Lower the better
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 09-12-2006, 10:50 AM   #4 (permalink)
Price of above LCD wrong .
LCD/TFT
L.G. 15" Rs8200
L.G. 17" Rs10600
L.G. 19" Rs14000
SAMSUNG 15" 540N Rs8300
SAMSUNG 17" 740N Rs10400
SAMSUNG 19'' 940BW Rs14500
BENQ 19'' BW Rs13800
PHILIPS 15" Rs8100
PHILIPS 17" Rs9800
PHILIPS 19" Rs13700
VIEWSONIC 15" Rs8400
VIEWSONIC 17" Rs9800
VIEWSONIC 19" Rs13900
SONY 15" Rs9000
SONY 17" H8-75A Rs12000
SONY 19" H8-95 Rs16500
ACER 15" Rs8000
ACER 17" Rs9500
ACER 19" Rs13400
HP 17" Rs12600
All LCD competable tv tuner work
nirali is offline
Old 11-12-2006, 11:32 PM   #5 (permalink)
is costing around rs.8500/- and if the above post is correct then the taxes and implementation of prices are just upto valious marks and shows that all the latest computer dealers are fools...
DONT GIVE WRONG INFO HERE AS IT MAY HARM... I BET ON PRICES AS I MYSELF SELL IT ON THE SAME PRICE YOU WANT IT..
Old 12-12-2006, 02:06 AM   #6 (permalink)
pra_2006's Avatar
i want to know which LCD monitor can support watching television without using my pc and should support tatasky
Old 13-12-2006, 12:42 AM   #7 (permalink)
any monitor yaar.. go for samsung its ok while watching tv without using pc
Old 13-12-2006, 01:21 AM   #8 (permalink)
pra_2006's Avatar
okay thanks for ur replies
Old 13-12-2006, 01:38 PM   #9 (permalink)
Tux Fan
shaunak's Avatar
Tatasky uses regular composite out put.
Look for it on the back of the monitor [ask the dealer]. It looks like:
Its basicaly how you connect you DVD player to a standard TV.
Also remember to change you set top box config to wide [16:9] format.
[Look in the organizer menu.]
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 13-12-2006, 04:39 PM   #10 (permalink)
pra_2006's Avatar
shaunak can u pls tell me which LCD monitor can support this pls reply me fast
